Home > Technical (L322) > Front End on bumpstops most mornings
Outlawd3
United States 2007 Range Rover HSE 4.4 V8 Stornoway Grey
Hello, first time poster, long time reader. I have a 2007 L322 HSE, new to me. It has developed the condition of the front end sinking to the bump stops most mornings. Not always, but most. Rear end does not drop. I have checked for leaks and can not find any anywhere, I have replaced the front air control valve thinking that it might have been leaking internally, but no change. It has a new battery. I am ready to replace the front air struts to rule that out, but thought I might see if anyone had ran into this and I might be overlooking something simple. I do have the iidtool and have put in build mode and it has still leaked down. Thanks for any suggestions.
Post #536614 6th Dec 2019 11:03pm
Does/will your car achieve full off road height?
Post #536618 7th Dec 2019 12:47am
Outlawd3
Yes it does.
Post #536619 7th Dec 2019 12:57am
GraemeS
Go to off-road height then spray soapy water around the base of both air-springs which will probably reveal a multitude of pin-holes, possibly on both. Consider replacing the whole strut rather than just the air-spring, maybe both even of only 1 is leaking as the other wont be far behind.
Post #536620 7th Dec 2019 4:58am
Outlawd3
I have tried that, but certainly will try it again. It seems like it takes it over 8 hours to start leaking down. I will plan on replacing both air struts. I do park on a slight incline at home. Would the self leveling be causing any of this or height sensors ? The height has been calibrated and seems to go right back to that. I just wanted to see if anyone else had ran across this to see if there was something else I might be overlooking.
Post #536656 7th Dec 2019 3:30pm
dexion7
2010 Range Rover Vogue SE TDV8 Alaska White
when the engines off, doesn't the ecu check height sensors every 2 hours or so and deflates air bags to compensate?
since you're parked on an incline maybe this is relevant, perhaps faulty height sensors etc?
can't currently find any other posts about this so happy to be told I've dreamt this up Laughing
Post #536658 7th Dec 2019 4:19pm
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
Try parking the other way round , if still dropped than it isn’t the ecu compensating fir the slope 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #536659 7th Dec 2019 4:25pm
mjdronfield
Mine does the same if left for 2 or 3 days. My TD6 did too. In fact I seem to remember the back went down too after a week or so.
Fine as soon as I started the engine up.
Never worried about it as it was fine normally. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #536660 7th Dec 2019 4:30pm
Outlawd3
dexion7 - I had wondered the same thing. I might start with new height sensors.
V8 Bob - I did try parking the other way and it still went down in the front, so I agree with you not the ecu compensating
mjdronfield - I had first noticed mine after 2 or 3 days of not driving also and yes my back did eventually go down after a week or so. But mine did not go up after I started the engine, stayed down until I inflated with the gap tool.
I am wanting to put a bigger tire on and am afraid if this is normal, it would eventually damage my fenders by going down. I am wanting to achieve a set height all the time if possible.
Thank you all for your input.
Post #536663 7th Dec 2019 4:45pm
GraemeS
If the 20A main suspension fuse is removed overnight then the system cannot lower unless air is escaping from somewhere. I expect that in the morning one front corner would be lower than the other indicating a leak in the lower side.
Are the top nuts tight? If not then they can leak.
Post #536681 7th Dec 2019 7:34pm
Outlawd3
I removed the 20 amp fuse and parked on level ground last night. The front end was on the bumpstops again this morning. So I am convinced it is a leak. I would think if one of the front air bags is leaking it would only go down on that side. Is that not correct ? Or does the system leak out both through one or the other front air bags, if one had a leak ?
Post #536727 8th Dec 2019 3:41pm
nino_nino
behind front right wheel liner is cross over valve for front suspension. check that for leaks. 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #536730 8th Dec 2019 5:37pm
Outlawd3
I had checked the cross link valve and seen no visible leaks, but went ahead and replaced it last week in case of internal leak, but still goes down in the front overnight.
Post #536734 8th Dec 2019 6:04pm
GraemeS
Both air-springs are likely to be leaking. The holes generally start as pin-holes then get bigger and more occur. However make sure that both top nuts are properly tight, for which you will need an Allen key or Allen key socket to hold the shaft and a ring spanner for the nut.
Post #536740 8th Dec 2019 7:45pm
Outlawd3
GraemeS - on the top nuts, are you talking about the 3 at the top of the strut that are visible under the hood ?
Post #536744 8th Dec 2019 8:00pm
