Home > Technical (L322) > Heavy steering - 2010 3.6 TDV8 |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 693 |
Here's the link to the list I compiled originally from info elsewhere + the Jag workshop manual (which is lot more useful than a Range Rover manual !).
26th Nov 2019 1:31pm |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 680 |
I've just had a read through Pawl and I feel most of the items mentioned have been covered.
26th Nov 2019 5:56pm |
Went ahead and replaced the dayco belt with a genuine land rover belt Sunday just gone.
4th Dec 2019 4:58pm |
And frustratingly, revving the engine to 3k rpm still lightens up the steering. At least whilst stationary.
4th Dec 2019 9:34pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4307 |
Has it been looked at by a decent independent LR/RR specialist? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
5th Dec 2019 7:21am |
Hi Dr Rob,
5th Dec 2019 7:27am |
Rovertune in Reading Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
5th Dec 2019 9:38am |
Thanks for the suggestion but I'm in Cheshire/Manchester areas so a bit far away. |
5th Dec 2019 10:04am |
A possible interesting note, just ohmed out my old servotronic valve that I removed from the car and it measures under 1 ohm.
5th Dec 2019 7:40pm |
That's definitely not near spec. so would have been doing something odd to the steering.
5th Dec 2019 8:15pm |
Hi Pawl,
5th Dec 2019 8:39pm |
I know what you mean about the hire car - lol.
5th Dec 2019 10:14pm |
Ended up with a new ish toyota Corolla hybrid. Not a fan of the drive train but loving the light steering and surprisingly compliant ride.
6th Dec 2019 10:41pm |
Forgot to mention that I also have the following permanent codes stored in the BCM. (Picture attached)
7th Dec 2019 8:59pm |
