![]() | Home > Technical (L322) > Sorry !! AGM or No AGM ? |
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1099 ![]() ![]() ![]() |
I doubt all of your issues are to do with the battery !
Ragingrover Member Since: 05 Oct 2019 Location: Malvern Posts: 152 ![]() ![]() ![]() |
I've read so much about problems relating to even slightly low battery voltage, including the FBH. I like the easy fixes first :¬) .. where possible of course ! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35629 ![]() ![]() |
yes , yours should be an AGM... ... - .- -.
Great thanks, AGM it is then |
Battery might fix the FBH, doubt it's the radio issue though Current: 2011 FFRR Vogue SE 4.4 TDV8
M@r]{ Member Since: 03 Nov 2019 Location: Northants Posts: 165 ![]() ![]() ![]() |
Should all the batteries in the L322 be AGM then? I don't think mine is?! |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3817 ![]() ![]() ![]() |
All 2010-12 4.4 tdv8’s should be AGM. G reg 2.5VM Vogue Portofino red 1991- 1999
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
I just bought an Exide AGM for £125 from euro car parts. Fitted it yesterday 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 ![]() ![]() ![]() |
If you mean the radio won't stay on for more than 5 minutes with the engine off, then yes I'd say your symptoms point to a dying battery.
