Home > Maintenance & Mods (L322) > Front door won't open from inside or outside
seany150
United Kingdom 2006 Range Rover Vogue SE TDV8 Buckingham Blue
Morning all got an issue with the l322. Went in it this morn to defrost it and all was fine, left it ten mins missus went back out and says the drivers door won't close. Tried shutting it and it wouldn't latch, finally managed to get it to close but now it won't open from the inside or outside handle
I replaced a cable about a year ago as the outside handle wouldn't work but this is both handles so having to climb in from the passenger side now
Any help would be much appreciated
Post #536115 2nd Dec 2019 9:33am
rjff
Possibly a frozen lock mechanism. See if you can leave it parked with the door facing the sun.
Happened to someone or two on here ISTR. Cheers
Richard
Gap IIDBT
Post #536117 2nd Dec 2019 9:49am
its a common problem as is the sticking door which can be sorted by putting gummi pfhlege on the rubbers..
the frozen latch/lock needs to be dried out and covered in grease... ... - .- -.
Post #536121 2nd Dec 2019 10:00am
Watering can full of hot water. Thumbs Up
Post #536124 2nd Dec 2019 10:32am
supershuttle
+1 for gummi pfhlege Geoff
Post #536129 2nd Dec 2019 11:11am
seany150
Cheers you was all right, just had a phone call to say it's working fine now
Much appreciated
Post #536151 2nd Dec 2019 3:31pm
