Home > Maintenance & Mods (L322) > Removing rear wiper arm and blade. Any tips ?
Baltic Blue
My rear washer stopped working last night.
I wondered if it might be frozen, but alas not.
I have had the supply tubes off and getting decent flow.
I have managed to clear one jet, but 2nd jet still blocked.
I couldn’t get the wiper arm and blade off. Do I need a puller, or more leverage ?
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #535980 30th Nov 2019 4:48pm
DrRob
Wiggle it a little bit but hold it tight near the splines with other hand if that makes sense.
Have you lifted arm clear of glass so it’s sticking out into the air? Apologies in advance if granny is sucking eggs Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #535981 30th Nov 2019 5:04pm
Baltic Blue
Thanks Rob, but once the nut and washer off, no amount of tugging and wiggling would budge it.
I tried a large screwdriver behind it , levering against a piece of wood, but no joy. The motor was lifting within the mounting grommets ?.
Seems hard to believe but I have had a L322 for 14 years now and never needed to remove the arm before.
Post #535984 30th Nov 2019 5:18pm
Spud
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
You a wiper arm puller. Cheaper than replacing the glass!
https://www.ebay.co.uk/itm/Car-Windscreen-...SwTJJd4nyM 2006 4.2 SC
Post #535986 30th Nov 2019 5:29pm
Spud
Use not You Mr. Green 2006 4.2 SC
Post #535987 30th Nov 2019 5:30pm
Baltic Blue
Thanks Spud,
I have just ordered one.
Luckily no rush to fix it because I have now got a really good flow from 1 jet.
Post #535988 30th Nov 2019 5:33pm
Spud
Little tip for when you use it. Make sure to leave the retaining nut on the spindle, loosened a few turns of course. It saves from damaging the thread should it prove to be a little tight, which it obviously appears to be. 2006 4.2 SC
Post #535990 30th Nov 2019 5:37pm
Baltic Blue
Just to note..
The puller in Spud’s link arrived within a week and worked brilliantly.
Wiper arm off, 2nd jet cleared and now good as new Thumbs Up
Cheers
Post #537418 14th Dec 2019 6:26pm
