![]() | Home > Camping, Caravanning and Holidays > Towing bliss |
ilard Member Since: 21 Oct 2012 Location: London Posts: 713 ![]() ![]() |
Sounds like a perfect use case for a 4.4 FFRR and a life-changing step up from your prior tow cars. Enjoy! I hope it serves you proud. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16332 ![]() ![]() ![]() |
I know what you mean, its quite disconcerting towing with such a great tow car the first few times...
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1291 ![]() ![]() ![]() |
Thanks for the comments. Just out of interests sake, when I had the gearbox oil changed at a ZF specialist, when I tow the caravan they advised me to use the sports mode when going slowly through villages to help the torque converter from excessive slipping and getting to hot. I didn't find the need to use it, even though sometimes the revs were barely above 1200rpm. It didn't feel strained and readily changed down a gear and just felt smooth. |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 374 ![]() ![]() ![]() |
Love mine for towing ( and everything else lol ) effortless and much less strenuous than a manual. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8741 ![]() ![]() ![]() |
^^ I think that is because sports mode will chose 1st gear if needed whereas the D will set off in second unless you manually select 1.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3551 ![]() ![]() ![]() |
I thought ours pulled away in 2nd but actually I've been monitoring gears selected and engaged and it downshifts through the gears as you slow all the way to 1 then up again from 1 from standstill. This is in D not S
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
When a trailers connected to ours there is a noticeable change in the way the gearbox shifts and the engine behaves. When the tow bar was first fitted I tested it straight away, before coding the vehicle it wasn’t until it was coded that there was a noticeable change in the way it drove. Presumably it’s clever enough to adapt when a trailer is connected, so I wouldn’t have thought S was required?
