![]() | Home > Group Buys > The all new Reversing LED bulb (CANBUS) Group buy |
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1099 ![]() ![]() ![]() |
PMs sent |
Gfenton Member Since: 25 Nov 2019 Location: York Posts: 9 ![]() ![]() ![]() |
Hi Bushy
MartynSeaman Member Since: 13 Apr 2019 Location: Essex Posts: 10 ![]() ![]() ![]() |
Hello, are you still doing bulbs please, thanks |
jc132jc Member Since: 05 Nov 2019 Location: Suffolk Posts: 32 ![]() ![]() |
Bushy30, can I have a set please ? |
walkingTech Member Since: 25 Nov 2019 Location: North Somercotes Posts: 3 ![]() ![]() ![]() |
Hi Bushy,
OK folks, there are five of you after sets with only 2 sets left remaining.
Hi Bushy, I'm definitely in for a set whenever available, thanks. 2011 4.4TDV8 Vogue |
Roadrunner001 Member Since: 26 Nov 2019 Location: Derbyshire Posts: 1 ![]() ![]() |
Hi Bushy
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
I am in if you are able to ship to me Bushy. |
FFRRWannabe Member Since: 19 May 2019 Location: Snohomish WA Posts: 39 ![]() ![]() ![]() |
Count me in. 2011 Range Rover Autobiography
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 ![]() ![]() ![]() |
Please count me in for ether the current batch or new order. |
WB Member Since: 26 May 2016 Location: London Posts: 303 ![]() ![]() ![]() |
Any chance we can see what's on offer here? Is it a replacement LED bulb? Seem to be loads on the bay just curious if these are similar or something else?
@WB -- they are canbus LEDs that replace the reversing bulb -- most you find elsewhere will not be short enough to fit, some have tried with others and melted the plastic lens.
Thanks for the quick reply. How does warranty work on them? I generally tend to buy branded bulbs from Amazon so they can go straight back if there are any issues as I found unbranded LEDs often work at first then either fail/blink/go intermittent etc. |
