Home > In Car Electronics (L322) > Digital TV no picture, is this the correct unit?
M@r]{
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Barolo Black
Found something that doesn’t work on my new to me car! Shocked Shocked
Digital TV has no picture, DAB radio works a treat. Auto brings up no channels, can’t locate any with the manual search. Country is set to uk, format Pal B?
Did a search on here and someone had a similar problem, a new tv unit sorted it, however they mentioned a description of the wording in their unit that doesn’t match mine, mine says Hybrid for a start. Is this the correct one for watching digital tv in this country? If not, is there someone in the midlands area that wouldn’t mind a quick swap to see if the issue is with my
Unit?
Here’s a picture of my unit:
Post #534558 17th Nov 2019 12:19pm
Discotigger
That's the correct unit, I have a spare unit from my old FF with the same serial code and it worked perfectly on my FF. If your unit is fubar you can get a replacement from ebay, or you could PM me and I can sell you my spare unit.
Post #534617 17th Nov 2019 6:55pm
M@r]{
Cheers, pm sent
Anyone know if the dab radio uses the same antenna as the digital TV? If so I know that’s not the issue as the dab radio works great
Post #534623 17th Nov 2019 7:17pm
Maybe obvious, but try tuning in a different place before assuming an issue - sometimes it's just down to there being no signal where you are.
Post #534642 17th Nov 2019 9:07pm
paulbrown22
United Kingdom 2011 Range Rover Supercharged 5.0 SC V8 Stornoway Grey
Sounds very similar behaviour to what I found when I bought my vehicle a couple of years ago: https://www.fullfatrr.com/forum/topic46293.html .
I swapped out the tuner module for a second hand item, and it's been perfect ever since - wife watches it all the time when we are in the car!
If you are going to get another unit, make sure you do get the exact right one, as there's various ones for other regions out there that don't work in the UK. Mine was technically a D4 one, which is the same physical unit but used the top rather than side mounting holes. A few mins work with a tap set, and it fitted straight in to the original mounting holes in the L322.
Post #534654 17th Nov 2019 11:06pm
Discotigger
PM received and response sent Thumbs Up
Post #534722 18th Nov 2019 6:26pm
GDM
United Kingdom 2006 Range Rover Vogue Td6 Zambezi Silver
M@r]{ wrote:
Cheers, pm sent
I didn't realise you could get DAB in an L322. What year is your car?
Post #535270 23rd Nov 2019 9:12pm
M@r]{
Mines a 2012
Post #535278 23rd Nov 2019 11:09pm
GDM
Must be a different system on the later ones. Mines a 2006 MY which I fitted the later hybrid tuner to temporarily a few weeks back but it didn't seem to add DAB. I need to make up some brackets to get it fitted in permanently.
Post #535339 24th Nov 2019 5:52pm
you can only get DAB from 2010 onwards....there are aftermarket jobbys available. ... - .- -.
Post #535341 24th Nov 2019 6:11pm
