![]() | Home > Technical (L405) > Suspension L322 vs L405 |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2644 ![]() ![]() |
The L322 and L405 front suspension at least are quite different, with the L322 using a McPherson strut and the L405 double wishbones. Damper rates are likely to be different and are different on at least the MY11/12 L322 between the 4.4 TDV8 and the 5.0 SC. |
John1000 Member Since: 08 Apr 2018 Location: London Posts: 23 ![]() ![]() |
Hi, thanks. The MacPherson design has a much smoother ride at highway speeds so I do not get why the reported ride improvement for the L405. I struggle to see the technical reason for it
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1401 ![]() ![]() ![]() |
Comfort on both is good, my guess would be that the adaptiveness of the suspension on the 405 is more sophisticated, with more advanced software. Early 322s didn't have adaptive dampers at the back I think, and the ride of later 322s was better than of earlier ones (comparing new for new). Tyre technology will be a factor too, more modern tyres will have lower rolling resistance and lower noise. Only Range Rovers since 1988 |
Any L322 that has adaptive dampers has them front and rear.
