![]() | Home > Technical (L322) > What should the battery voltage be when parked? |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
Interesting.
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
Yep, offside, left from the front.
Pulled fuse 13 from the engine bay and it made no difference.
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
Did the FBH outlet pipes get warm?
Andy
I could hear it running the other night when we jumpstarted it. It ran with the engine and I could hear ticking from the rear offside. Hasnāt done it since though.
If the FBH is running properly you should feel hot exhaust gas aand/or a hot FBH exhaust pipe. If it's cold then the FBH is not firing. I don't know if the pump for the unit continues to run if the FBH is not firing up.
Yes I have. Iāve just ordered a 13 pin plug to fit to my aldi charger. I used to charge my TD6 this way. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
Cracking, I've got the same Aldi one and it's fine like that. Cheers
Andy
Thanks Richard. I did see that thread doing a search for FBH problems but didnāt read it thoroughly.
Andy
When the RAC checked it, it was fluctuating between 14.1 and 14.2 when running so I think itās ok. It has had an alternator fitted prior to be buying it as well so it āshouldā be ok.
Sounds fair then. Trust the new battery solves the problem and that it is a faulty cell on the old one. |
