Home > Technical (L322) > Dreaded Air Suspension Inactive, HDC, ABS & No Speedo |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3085 |
Not sure if any of what follows is a solution for your woes (and you probably know this anyway) but all the abs, hdc etc are connected through the canbus so if only one of those sensors faults, it trips all the others.
19th Nov 2019 10:12am |
n3ddy Member Since: 05 Dec 2015 Location: Brisbane Posts: 5 |
I've checked (and cleaned) where the sensors connect at the wheel bay but not in the engine - Will have a look today, thanks for the suggestion! |
19th Nov 2019 11:21pm |
Slow Member Since: 09 May 2015 Location: Inverness Posts: 39 |
Not related to your fault but how did you find the johnson rods for quality and to fit?
21st Nov 2019 8:10pm |
Snowy90 L322 Member Since: 24 Aug 2015 Location: Surrey Posts: 220 |
Steering angle sensor?
21st Nov 2019 8:12pm |
