Home > Technical (L322) > help please asap |
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 |
Often I can get a smell of unbutnt fumes through the vent , and if that mess is near the pollen filter then its something to do with the fuel burning heater if you have one. |
17th Nov 2019 12:53pm |
dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529 |
hey buddy its coming from the black mess in this pic not the fbh Regards
17th Nov 2019 12:55pm |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
Boost hoses? |
17th Nov 2019 6:23pm |
Found out its a egr tube, land rover crushed the flange and under hard throttle its was leaking to the point exhaust fumes were being sucked in via the HVAC and the heat from the engine was causing smoke .. lots of smoke Regards
17th Nov 2019 6:35pm |
Ouch, hope you get it sorted, there's nowt worse than smoke in the cabin! |
17th Nov 2019 6:46pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3545 |
Where is that pic in the engine bay Daz?
17th Nov 2019 7:08pm |
ITS the very rear of the engine mate, part now identified lol.. Regards
18th Nov 2019 11:35am |
Land Rover agreed there technician crushed the flange of the pipe. So new one arrived today f.o.c and I fitted it myself. Pig to do becuase there is what looks like a high pressure rail or similar right about it and the heat proofing around the tube made it really hard to locate properly.
19th Nov 2019 9:10pm |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 |
Blimey, if they broke it they could fix it!! Lunatics.. Current: TDV8 (3.6) RRS HSE
21st Nov 2019 6:57am |
Any more pics Daz?
21st Nov 2019 7:27am |
See if this helps Greg. It’s the very very rear of the engine.
21st Nov 2019 11:40am |
Nice one Daz Cheers, Greg
21st Nov 2019 11:57am |
Are you suspecting problems with yours Greg? Regards
21st Nov 2019 12:17pm |
Just going to check out that area / union - a bit of a diesel waft under the bonnet, not sure if normal.
21st Nov 2019 7:34pm |
