![]() | Home > Maintenance & Mods (L322) > Handbrake cable bolt |
RichM63 Member Since: 10 Jul 2019 Location: Brittany Posts: 249 ![]() ![]() ![]() |
Are you talking about the EPB cable to brake backing plate screw?
No EPB on an '02 .
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2218 ![]() ![]() ![]() |
On about my 07 |
nice first post edit |
Moulded end of the outer cable that allows the cable to be attached to the brake backing plate and also prevents the whole cable from being pulled through when applying the EPB. The screw/bolt does go through it in about the 9 o'clock position. |
Ok great - anyone know about the bolt is it an m6? Current stable:
M6 10mm Torx
thank you Current stable:
