Home > Technical (L405) > Tyre Pressure sensors: 2019 vs 2014?
Emperor Mong
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Loire Blue
I have a 2019 PHEV. I traded up from an early 2014 car (March, I think).
On my 2014 L405, I could put my offroad wheels on and the tyre pressure sensors would immediately be recognised.
Same wheels/pressure sensors on my 2019 car are not.
Does anyone know if the pressure sensors changed or if it is a question of programming them to the car?
If the sensors changed, do new sets need programming? If so, does it forget the first set? If yes to that, can I buy a tool to do it to say the faff of going to dealers each time I swap wheels?
If the sensors didn't change, same questions, I guess.
Thanks
Post #534779 18th Nov 2019 10:53pm
brad s1
2004 Range Rover HSE 4.4 V8 Giverny Green
the 19 wants 433mhz and the 14 is something like 315mhz... You need 433mhz sensors.
Post #534781 18th Nov 2019 11:02pm
when fitting 'other' tyres/wheels then it takes 10 minutes of driving or around 18 miles for the sensors to be recognised ..if yours dont then i'd ask the dealer why... ... - .- -.
Post #534791 19th Nov 2019 7:28am
I read a post from Craig which said early L405 sensors are compatible with L322's, but then they changed around MY16 and later ones are not compatible with either....
Post #534792 19th Nov 2019 7:38am
this from the WM says the change in frequency relates to the american market and that the UK frequencys are all 433mhz..
Post #534795 19th Nov 2019 8:14am
