![]() | Home > My Range Rover > My dead TDV8 / turbo failure / moving onto a 4.2SC |
fanders Member Since: 10 Jul 2013 Location: Hants, UK Posts: 318 ![]() ![]() ![]() |
For what it's worth I put together this checklist when I did the pre-buy inspection on my new 4.2SC Rangie, it's based on one on the wiki but reformatted as a one-page checklist with tickboxes and has a few SC-specific items on there. It might be helpful for someone looking at a used L322:
Managed to get a few nice pictures of the new 4.2SC today in the sunshine. Next step will be to detail the paint, which is ok as is but has a lot of small swirls in the lacquer layer:
Also installed the obligatory forum sticker:
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2276 ![]() ![]() ![]() |
Enjoy I have had mine for 5 yrs and put over 120k on it - its now on 185k- and it is still going strong
Thanks Sandyt, I was reading about yours when I was deciding what type of L322 to buy when the TDV8 died. Sounds like you have a good one too. I will be doing all the routine servicing on this new 4.2SC (my old TDV8 went to my local LR Indy for regular servicing), and am planning the following oil/fluid service intervals:
The transfer case input/output shaft seals are being done this week, so that will be done, but I will be slowly going through all the other items in the next couple of months to bring it all up to date. It will be interesting to examine the rear differential oil, I don't have all the receipts for this vehicle but imagine that the oil is original. I'll post what I find. fanders ![]() Last edited by fanders on 15th Nov 2019 2:54pm. Edited 1 time in total |
Almost there with stripping the old TDV8 of useful parts before it goes off to the scrappy before Christmas on a trailer, just need to remove the window regulators, windows including front screen and the electric park brake unit.
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 605 ![]() ![]() ![]() |
WOW |
RichM63 Member Since: 10 Jul 2019 Location: Brittany Posts: 249 ![]() ![]() ![]() |
Hey friend, don't suppose that you still have the longitudinal air tank under the driver side twixt sill and chassis.
Hi Rich, yep it’s still there. I’ll pull it out and send you some pics. If you want it I can drop with your chum in Petersfield.
Sounds good to me. |
Fateful day came yesterday when it was time to take the dead TDV8 L322 off to the great car graveyard. Sad but nice to have the driveway space back. Good job I have another L322 to tow it with:
I and some forum members here had had quite a lot of parts from it, not much worth having was left: Shortly to become new frying pans etc: £231 for the hull, quite pleased with that as it more than covered the trailer hire and petrol. So long grey Rangie, long live the blue 4.2SC Rangie! Cheers, fanders ![]() |
quavey Member Since: 22 Jan 2017 Location: Lancaster Posts: 304 ![]() ![]() ![]() |
It seems a crying shame to have skipped what looked like a fairly straight shell still with panels and some glass in!
Yep shame to see it go although it was fairly rusty underneath/sills/rear arches. The doors were generally ok but at £45 per door skin the shipping on top of that was way more that they were worth. Alloys fairly crusty too and the bonnet was corroding all around the edge due to a priming defect from new. Scrappies - it’s the way they all go in the end!
With a bit of time free over the Christmas break I though I'd have a look at the sills and rear arches on the new 4.2SC, and rectify any defects found. As the vehicle is generally very rust free, I was hoping not to find too many horrors. So, up on jacks and off with the sill trims and rear arch liners:
Once the sill trims were off it was clear that someone had been here before, with a waxy residue visible on the sill access holes - a good sign: A look inside the sills with my wifi iPhone borescope camera (£15 well spent on eBay) revealed that the inside of the sills were in excellent condition with no rust, coated with a layer of light brown wax: The rear arches did have a little light surface corrosion on the thin return flange, but were otherwise very good: So, I attacked the surface rust with some emery cloth and soon found the steel beneath: Whilst I was in there, I painted the brake disk centres with VHT silver as they were a bit tatty: And then masked up and painted the sanded-down areas with rust-eater, then chassis black paint followed by Buckingham Blue topcoat: I also painted the lower wishbones with rust-eater and chassis black to smarten them up, as they were a bit rusty: It was then a case of waxing the sill cavities before reassembly, with 3M Cavity Wax Plus: This in an excellent product with nozzles that spray the wax in a 360 degree fan due to the nozzle design. I also injected grease into other folds in the rear arch skins: Before putting it all back together again. I added the extra rear arch lip rubber trims on the unprotected forward sections of the arch flanges as per the other threads on this subject, having got two LR001623 Freelander 2 'wheel arch protector water shield' rubber trims from Keith Gott's for £18. They didn't need much trimming to fit, just 1/4" off the end worked fine. I loaded them up with grease before installation. I also sprayed the inside of the arches with clear Waxoyl to protect this area: So all in all a pleasant surprise in how free from corrosion my sills and rear arches were, as my old TDV8 was suffering badly in that department prior to its expiry. I'll inspect these areas annually to check condition and renew grease/wax protection, and be careful pressure washing the arches to avoid blasting out the grease on the arch lips. |
Looking good and rust free. |
