![]() | Home > Maintenance & Mods (L322) > Supercharger removal |
MattHughes86 Member Since: 01 Jun 2019 Location: Gloucestershire Posts: 140 ![]() ![]() ![]() |
Hello,
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2231 ![]() ![]() ![]() |
No worries - many thanks - on the if I leave the cooler hoses connected can I lift them up at all? I need to change once of the manifold gasket as it leaking but could do without messing around with coolant for the sake of it
it might be quite a fiddle but should be do-able, easiest way is to try
Well spent about 6hours today took the blower out - for anyone doing this a couple of time saving shortcuts -
can you explain where the oil is for the super cahrger?
there's a torx bolt to the side of the pulley take it out tip it up on its side everyday until empty then refill with syringe,,, Current stable:
i will have a look at that when i dig it back out.
this bad boy :
m@ttsFF Member Since: 12 Dec 2017 Location: Surrey Posts: 333 ![]() ![]() ![]() |
Check that it is indeed a torx bolt ... pretty sure it’s an imperial sized Allen head around 5/32 4.2 SC - sold , now bought back
