Home > Technical (L322) > FOUND REASON!Smoke from left hand side and fumes in cabin??? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7797 |
Not sure really, but the fuel burning heater is under where the battery is, under the wheel arch and it has its exhaust there too. You prob know that already......and I’m not sure it would still be running that long after startup, so may be a red herring...... 2011 Range Rover Vogue SE 4.4 TDV8
14th Nov 2019 4:34pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
Probably the FBH now that weather is colder. Exhaust is behind passengers front wheel. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
14th Nov 2019 4:39pm |
dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529 |
Wonder why the fbh would kick in or still run after that time. Engine was well up to temp.
14th Nov 2019 5:14pm |
Anyone else ever experienced this.
14th Nov 2019 7:33pm |
MattyB1983 Member Since: 05 Feb 2017 Location: Cambridge Posts: 81 |
Itll be the FBH, mine does the same from time to time even after a drive |
15th Nov 2019 7:20pm |
Cheers matty.
15th Nov 2019 7:33pm |
Blooming car did this again today.
16th Nov 2019 8:42pm |
Have a look over on Disco 3 forum. They have a FBH section
17th Nov 2019 9:05am |
ok, so had the wheel arch liner off and got the wife to rev the card hard and violently and the smoke and diesel smell is coming from the rear of the engine, a rough area guess is undernerath the pollen filter chamber area.. anyone any ideas??? Regards
17th Nov 2019 12:05pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
Oil cooler ? .
17th Nov 2019 7:09pm |
Egr tube joe.
17th Nov 2019 7:12pm |
That’s is one serious safety issue that I would play merry hell over! Diesel fumes in the car is a big no no.
17th Nov 2019 7:18pm |
