Home > Technical (L322) > Fitting SP wipers from Amazon
alfapat
Scotland 2004 Range Rover Vogue Td6 Bonatti Grey
Shouldn't be too tech ., but for the life of me has anyone fitted these with the array of adaptors? There is supposed to be a Video, haha!
https://www.amazon.co.uk/gp/product/B0765Y...&psc=1
Cheers Pat
Post #534147 13th Nov 2019 8:38pm
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
Got the same blades of flebay. Just took old wipers and they fit straight on no problem, a lot quieter with much less noise on end of stroke. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #534152 13th Nov 2019 8:53pm
alfapat
No help, just trying to see if someone else have bought these and would know the the link to video identifying adapters.
Post #534156 13th Nov 2019 9:04pm
V8 Bob
Didn’t need any adaptors fit straight onto wiper arms 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Post #534176 13th Nov 2019 10:49pm
alfapat
Ok will try again , maybe missed that , can’t see wood for trees’!
Post #534177 13th Nov 2019 11:29pm
dexion7
2010 Range Rover Vogue SE TDV8 Alaska White
put a thick towel on your windscreen under the wipers to protect the screen as the arm may spring back and damage screen.
remove old blades from thier arms - you may find that some of the plastic bits are broken anyway. you want to remove ALL plastic parts, clips etc from the ends of the arms so all you have left on the arm ends is metal. its possible that some plastic parts may break off but your going to bin all plastic parts anyway.
the new blades just clip on to the arm and are located by 2 pins which locate in holes in the metal arm.
and the only concern is that the pins on the new blade are not fully round (you can see they are actually semi circular in the amazon picture) it looks like they will not have not fully engaged with the holes in the arm. they do, however, and mine have been fine for prob 6 minths now.
Post #534179 14th Nov 2019 12:09am
alfapat
So are you talking about this sort of arm and does this slider connection come off.
Post #534189 14th Nov 2019 8:31am
it will be very obvious how it all fits when you get the new wipers and then remove the old wiper.. ... - .- -.
Post #534191 14th Nov 2019 8:38am
alfapat
Haha not that obvious as I have it in my hands right now , must be thick !
Post #534193 14th Nov 2019 9:19am
everyone has their limits...... ... - .- -.
Post #534194 14th Nov 2019 9:22am
Weegie
You have to remove the existing blade and then strip off all the plastic bits at the end of the arm so that, as said above, you are left with the bare wiper arm. The new blade just slips on to the end of the wiper arm.
Everything in your photo above needs to be removed. John
GAP iiD BT
Post #534197 14th Nov 2019 9:51am
alfapat
Ok , thank you for replying , perhaps this new blade which came with an adaptor on it is confusing things and needs to come off . I’ll send pic
Post #534207 14th Nov 2019 10:30am
alfapat
Adaptor off , but no way are they the same?
Post #534208 14th Nov 2019 10:36am
alfapat
So plastic off old arm
Post #534210 14th Nov 2019 10:47am
alfapat
The upshot is that what I ordered and what amazon sent was completely different. The company even said that the HQ Automotive blades were not fit for my vehicle , slightly raging and a video sent from Q&A on Amazon clearly shows what all you guys were trying to explain to me , someone fitting them to RR with the same blades!
Post #534250 14th Nov 2019 5:33pm
