Home > Maintenance & Mods (L322) > Both rear tyres wearing outer edges down |
pk7976 Member Since: 09 Mar 2017 Location: Kingston Upon Hull Posts: 33 |
Have just got in from an hour under the car and given everything a really good levering, with the car jacked up and the rear wheels removed i expected to see some movement in either the bushes or the rose joints on the rear suspension however everything is rock solid.
30th Aug 2019 6:51pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
When were the bushes and rose joints last changed? Was a four wheel alignment done at that time ?
30th Aug 2019 8:23pm |
S.Hafsmo Member Since: 02 Oct 2018 Location: Nordland Posts: 170 |
It seems strange to me that the anti-roll bar should have any influence on tire wear, as it does not affect wheel geometry.
10th Sep 2019 4:08am |
horsedentist Member Since: 23 Jun 2017 Location: london Posts: 158 |
Mine was only wearing on one edge (outside) there is no noticeable wear since we did the anti roll bars so I assume it was having an influence on the tyres we didn’t touch anything else on the rear. We did do front and rear roll bars as the links were all worn. |
10th Sep 2019 5:57pm |
Turned out as you all rightly advised to be the rear ball joints, I spent an afternoon under the back end, had it realigned and everything is good |
13th Nov 2019 5:08pm |
