Home > Technical (L405) > PHEV - vampire drain? |
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 |
I seem to have a serious battery drain going on.
12th Nov 2019 8:09pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35463 |
that software update sounds suspicious... ... - .- -.
12th Nov 2019 9:09pm |
@ Alistair
12th Nov 2019 10:10pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 |
Surely the CC must work with the vehicles main starting battery? Not the drive batteries.......
12th Nov 2019 11:01pm |
I believe that the PHEV has an electric heater matrix driven off the drive battery. For instance, it will heat the car in all-electric mode and you can preheat the car whilst plugged in without the engine firing or the drive battery depleting significantly.
13th Nov 2019 10:44am |
Came back to the car after c12hr.
14th Nov 2019 10:20am |
Spoke to the Technical Query bit of Land Rover Assistance. They had no idea, so it is off to the dealer with it. |
14th Nov 2019 10:43am |
its a shame you cant do a system restore back to before the update to see if it is the update at fault.. ... - .- -.
14th Nov 2019 10:51am |
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1099 |
You have had it a while so time for new batteries. letters not necessarily in the right order |
14th Nov 2019 2:22pm |
Maybe I put the wrong type of electricity into it? |
14th Nov 2019 2:27pm |
ilard Member Since: 21 Oct 2012 Location: London Posts: 712 |
You definitely have a faulty consumer unit at home, sir.
14th Nov 2019 10:38pm |
Yes, still like it. It works well under most circumstances. Unless you need to tow (and as long as you have somewhere to charge it), it is the best powertrain they offer currently, IMHO. |
14th Nov 2019 10:42pm |
