Home > Technical (L405) > FBH (Eberspacher) - Is this new remote control compatible??
awclymm
Hi
I see Eberspacher have a fancy new key fob remote available:
https://www.eberspaecher.com/en/products/f...-plus.html
Does anybody know if this is compatible with the FBH in a MY2017 Autobiography?
Thanks. 2017 4.4 SDV8 Autobiography
Post #533873 12th Nov 2019 8:22am
andygts
Accoding to this it is only compatible with the latest 'Airtronic' heaters, https://www.pfjones.co.uk/eberspacher-easy...41700.html
As far as I'm aware all L405s have 'Hydronic II' systems fitted. Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #533894 12th Nov 2019 10:17am
awclymm
Ah - I didn't know which specific model my car had, so that's very helpful. Thank you.
It's such a pity that the latest InControl app doesn't allow you to use the FBH - seems pointless having it on the vehicle if there's no way of using it...... 2017 4.4 SDV8 Autobiography
Post #533895 12th Nov 2019 10:21am
awclymm
It says here that the remote control WILL work with an Hydronic system??
https://www.ebay.co.uk/itm/232269485578 2017 4.4 SDV8 Autobiography
Post #533896 12th Nov 2019 10:42am
thats what andy said in his post... !! ... - .- -.
Post #533897 12th Nov 2019 10:44am
awclymm
Oops - I confused myself - I meant to say Hydronic, not Airtronic. I've edited the post... 2017 4.4 SDV8 Autobiography
Post #533899 12th Nov 2019 10:47am
ah ok...
thats a load of money for a remote, but you could confirm via email with the seller and then buy and try and if it dont work send it back.. .. ... - .- -.
Post #533901 12th Nov 2019 11:07am
andygts
Even if it does fire up the heater I'm not sure how much more it would do over the standard remote fob, I've got a feeling that once it is fired up Land Rover systems take over.
I'd want full functionality confirming before spending that much money. Current
Previous
Post #533913 12th Nov 2019 12:52pm
