![]() | Home > Technical (L405) > How many Locking Diffs do you have? |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7998 ![]() ![]() ![]() |
AFAIK you can't spec a front locker
Without lockers, we'd have struggled to get past half way & been much safer for it.... A front locker takes away the ability to turn tightly & the car tries to drive on - so really needs to be a manual switch The main case for a rear locker is for when you're cross axled - so the power is locked front/rear, but can then be lost because you have opposite wheels without grip - in this case a rear (or front) locker keeps both wheels on the axle moving at the same rate
Charles89 Member Since: 11 Nov 2018 Location: Leicester Posts: 268 ![]() ![]() ![]() |
Thanks for the wright up Alistair.
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1053 ![]() ![]() ![]() |
Mine has locking centre and rear, as I discovered on some wet grass/mud when out shooting recently. Came on automatically, but I still had to get a tow from a Defender to get out. Wrong tyres! |
ilard Member Since: 21 Oct 2012 Location: London Posts: 713 ![]() ![]() |
The rear active locking diff is standard on SDV8 and on any SVAutobiography. Everyone else pays for it, but not available at all on V6 (you can specify it on a P400e, however, as I have done). L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso |
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 ![]() ![]() ![]() |
Charles, although the original question’s been answered, may I recommend getting half a day’s training at a Land Rover Experience centre, if you’ve not been before? I’ve taken up every opportunity given to go on one and they run through all of this and a lot more besides |
Correct - I used to go to Tixover quite regularly when I had some toys - never taken a FFRR even on the gentle side. The LRE was at Rockingham - I got a 1/2 day thrown in when I bought the car, so gave that to my son & I went as a passenger. They had that section set up to demo the diff as you drive into it slowly, then get stuck with the opposite wheels spinning, then the rear diff locks up and you can drive off ![]() |
Wet grass can embarrass many a 4x4 - it can be surprisingly difficult to grip - almost like ice |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35610 ![]() ![]() |
agreed alistair, look at the end of this short video of a member on salisbury plain as he slides on wet grass..
I have taken my FF L405 to Tixover on many occasions. I've waded through 1M of water, and climbed every section apart from the Clay pit. I even did the rock crawl (much to the horror/shock of the onlookers in their play toys). But I've been shown how to use the car carefully, and if it can manage Tixover with ease, then it will cope with almost anything I throw at it in the real world. Ive done Rockingham in my own L405.. and when the winch is installed next Monday, I will be booking the winch recovery course also. In preparation for my up coming expiditions in 2020.
The main reason I was asking is that when your in off road mode the L405 only shows you 1 Diff on the screen and the status of locked or open etc. And the later 2017 shows you each diff separately on the screen so you can see when each diff is open or locked etc. |
![]() I'm more concerned with the narrower sections scratching it than anything else - but respect for being brave enough ![]()
I must admit, I thought the locking rear diff was always an option on the L405 - I'm embarrassed to say that I don't know whether I have one or not ![]() |
I looked at the 4x4 screen on the dash & only have the centre padlock
You’re not LWB? It’s not available on that SDV8. Otherwise, I am surprised but then I don’t have the brochures before 2016. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso |
charlie croker mk2 Member Since: 21 Jun 2017 Location: Yorkshire Posts: 174 ![]() ![]() |
Surely if say one wheel was to lose grip on ice or if it was up in the air ! the traction control would apply the brakes to that wheel only so as the spinning wheel would not rob the other 3 of traction . In effect creating its own locking diff . |
