Home > Maintenance & Mods (L322) > 3.6TDV8 Power Steering Pump Replacement
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
If you’ve decided to replace your PAS pump after exhausting the other easier, but not necessarily cheaper options to overcome heavy steering, here’s a “How to” to replace the PAS pump on a RHD 3.6 TDV8. I’m not sure how much might be different for LHD – if anything.
It’s based on the 2007MY Workshop Manual content & recent experience doing it with a successful result. It’s long, but covers everything as I’ve not found any other write-ups on-line.
Before this much effort, it’s worth getting the pump performance pressure tested on the car to make sure your problem isn’t in the steering rack, pipes or elsewhere. I’d exhausted other options via electrical testing & the pump pressure test confirmed I was only getting 30% of the output at idle – hence minimal assistance – and only 90% of the output even at 3000 rpm. A pressure test only requires Air filter box removal & the PAS reservoir draining before fitting the pressure test fittings onto the pump & HP pipe (I created the test kit as it’s not easy to find to buy).
I bought a cheap second hand OE ZF pump (unique for the 3.6TDV8) from a reputable breaker– originally only to check connections for the pressure test kit. However, due to comments on various forums suggesting the pumps were usually long lived if they weren’t leaking externally, I decided to use it on the car. Fortunately successful & only £40 vs £250+ new.
The whole job took me 7 hours (on the drive), but, it was the hottest day this year & I was very slow & taking lots of tea breaks - lol. Others have said it’s taken as little as 3 hours. It’s not technically challenging, but care & patience are required & getting the “hidden” bolt out is a real pain. Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #523103 28th Jul 2019 8:18pm
Pawl
Tools etc required :
    - 10mm socket & short extension bars + ¼ inch drive & 3/8 inch drive ratchets,
    - 8mm socket, 7mm socket for the above.
    - 21mm open jaw spanner
    - 22mm ring spanner (PAS HP output)
    - 21mm ½ inch drive socket, short extension & 18 inch or longer breaker bar (normal socket wrench if you’re strong – lol)
    - Hose clamp remover
    - Viscous fan spanner (36mm)
    - Posidrive / Phillips screwdriver
    - Small adjustable mirror on long flexible handle.
    - Torch / portable light
    - 1 litre of PAS fluid (Land Rover STC 50515 or equivalent)
    - 1 litre of OAT engine coolant
NB LHS , RHS etc refer to side of vehicle when looking from rear of vehicle towards the front.
Minor work underneath car : Raise vehicle to Extended ride height, remove front towing point cover, radiator splash shield retaining screws & shield.
1) Attach drain pipe to radiator drain plug on LHS of rad bottom, drain a approx. 1 litre from cooling system (collect via adding pipe on drain point. Objective is to get coolant level just below top hoses).
2) Remove 10mm nut from HP steering pipe rubber mtg on RHS of front subframe (21mm open jaw on flats on rubber mtg above subframe ). Push stud head out of hole to allow more scope to move HP steering pipe later.
3) Use ¼ inch drive 7mm socket to loosen LHS engine bank front air inlet duct flexible hose clamp from moulded plastic airbox “pipe”.
Lower vehicle to Access ride height for remainder of work in engine bay (Not needed if you’re tall – lol).
Remove air filter box : 4) Loosen & partially remove 6 cross head screws, disconnect MAF electrical plugs x 2, loosen MAF / Airbox outlet pipe clamps x 2 & remove small rubber pipe off suspension strut side of lower half of air box & remove air filter box top & air filter (rubber outlet pipes require pushing towards centre of car to free MAFs ). Remove MAF outlet pipe clamps from hoses to avoid damage & flex the pipes hard towards the centre of the car & lift the RHS of the lower half of the airbox up & out & remove the whole part from the spigots in rubber bungs in the inner wing (BEWARE : Don’t lose the large, loose rubber grommet between the air box & inner wing). Remove 8mm bolt retaining the windscreen washer bottle neck to the slam panel & carefully push the plastic mounting off the slam panel (avoids risk of breakage later)
Remove Viscous fan & fan top cover : 5) Loosen pipe clamps & remove RHS intercooler pipe from intercooler & plastic engine intake manifold.
Loosen RHS radiator end water pipe clamp & remove pipe from radiator. Free small cross radiator hose pipe from viscous fan top cover clips, loosen pipe clamp & remove pipe from LHS moulded plastic junction.
Loosen small rear facing pipe clamp & remove pipe from LHS plastic pipe junction.
Loosen main rear facing & radiator side pipe clamps & remove pipes from LHS plastic pipe junction.
Do same again for downward facing small pipe & remove the plastic junction piece.
6) Tie back LHS main water pipe (still connected) to allow access to LHS intercooler pipe clamps. Loosen intercooler pipe clamps & intercooler pipe from intercooler & plastic inlet manifold.
7) Loosen & remove 8mm bolts holding coolant expansion tank (at rear of tank, 4 or 5 inches below cap). BEWARE : Bolt threads may be rusty & tight (not moved in 10 years+). NB Workshop Manual doesn’t mention doing this step , but I found it helps a lot to create space when removing viscous fan top cover.
Disconnect viscous fan electrical connector from RHS of top cover rear face. Cool Remove 10mm fast thread bolts securing the fan top cover on LHS & RHS. 9) Push fan top cover backwards slightly & move it to the right to free it from RHS radiator water outlet. Manipulate top cover LHS free of LHS radiator water outlet & MAF outlet pipes & lift it upwards. Slide viscous fan electrical connector block towards the vehicle centre to remove it from cover.
You now have access to the fan !
10) Use viscous fan spanner to loosen large viscous fan retaining nut & remove the fan. I jammed a small chisel in between 1 of the 3 pulley retaining bolt heads & the fuel pump bracket to lock the pulley (special spanner necessary due to lack of space for normal open jaw spanner or adjustable spanner). BEWARE 1: Retaining nut is Left Hand thread ! BEWARE 2 : Some spanners are relatively short & leave the end you’re going to hit with a hammer very close to the fan blades – which are not very strong / easy to break ( I used some Loctite to repair 1 blade). Remove fan & it’s attached electrical connection.
Remove Auxiliary Belt : 11) Using 19mm socket, short extension & 18inch breaker bar, place socket on hex head of aux belt tensioner (in middle of the 3 idler pulleys) & apply torque in clockwise direction until belt can be slid from lower idler pulley. Then lift loose belt off PAS pump pulley.
Remove PAS pump : Use floor protection to avoid fluid stains. Empty PAS reservoir (Eg suck out contents with syringe & small bore plastic pipe OR lift from support bracket & attempt to pour carefully into a small container until almost empty . Total is less than 0.5litres). With reservoir lifted off its support bracket, loosen & remove reservoir inlet & outlet pipe clamps & pull off pipes / remove reservoir . Have absorbent cloth underneath to catch excess fluid !
Unclip plastic & additional small diameter rubber pipe from (engine bay centre side) the LH engine bank moulded air inlet pipe. 12) Loosen & remove 2 x 8mm bolts retaining moulded pipe to LHS side of radiator housing (from inner wing side of moulding). Thin hands required to extract moulded pipe from flexible pipe to Turbo (loosened from underneath while at Access height earlier) & remove curved section from around chassis rail & PAS pump / PAS pump pipes.
13) Loosen & remove PAS pump HP outlet banjo connection using 22mm ring spanner . Use absorbent cloth on floor or immediately under banjo to collect excess fluid draining from pipe / pump. NB Feed pipe from reservoir will also contribute to the volume ! Manipulate banjo & pipe around the PAS pump pulley towards centre of engine bay (out of the way for pump removal).
14) Using a mirror, identify location of rear PAS pump 10mm flange headed M8 retaining bolt (Not easily visible due to “hidden” position & foil protected AirCon compressor electrical wire in the way. See photo of pump off the car for assistance. BEWARE : If AirCon compressor wire is held by a cable tie to the bracket, cut or break cable tie to free wire. DON’T damage wire !
Using ¼ inch drive 10mm socket & short extension, attempt to get socket onto bolt head & loosen / remove bolt. Thin fingers are a big advantage. This step took me more than 30 mins ! NB Access / might be easier with the small sound deadening foam / cloth pad pealed off the inner wing ( I stuck ours back after installing replacement pump.
15) Loosen & remove both 10mm head retaining bolts on the front PAS pump mounting bracket (inner bolt will require short socket extension for access from centre of engine bay). Lift PAS pump out of place, avoiding fluid loss from still attached & open LP feed pipe.
NB : While Aux drive belt is detached, check all idler pulleys, AC compressor pulley, alternator pulley etc for smooth, noise free rotation. Resolve any issues.
Prepare replacement PAS pump for installation : Loosen LP feed pipe hose clamp & remove pipe from removed pump. Compare old & new pumps & ensure identical - especially pipe connections & pulley (BEWARE : Petrol engined & TD6 diesel pumps are similar, but have different connector positions & are NOT suitable). 16) If LP pipe connector inlet direction is not as removed pump, inlet can be rotated using force while holding pump in a vice & carefully gripping outlet with “cushioned” molegrips / adjustable spanner etc. Fit LP feed pipe onto new pump, ensuring pipe clamp tabs are pointing roughly towards HP connection position to avoid interference with engine parts on re-assembly.
Fit replacement pump : Manipulate pump into place, ensuring correct position of LP feed pipe & HP outlet pipe (HP pipe not fitted yet). Fit front face mounting bolts x 2 first, but don’t tighten. Locate rear ,“ hidden” bolt through bracket & into mounting hole. Ensure AirCon wire is not trapped before tightening all 3 bolts. Re-fit sound deadening pad with evostick or similar if it was removed earlier. Locate HP pipe connection banjo bolt in PAS pump threads – ensuring not cross-threaded before tightening.
Re-fit everything removed in reverse order of removal as above !
See schematic below if you’ve forgotten orientation of Aux drive belt round the pulleys
Underneath : Ensure radiator outlet drain plug is tightened & power steering pipe mounting isolator is re-fitted / secured on the sub-frame underneath.
Top up engine coolant with reservoir bleed screw open (I re-used drained coolant as it was in great condition), re-fill PAS reservoir with correct spec. fresh fluid.
Start engine, turn steering left & right a few times & re-check / top-up PAS fluid as required.
After running engine for a while, check & top coolant level as required (If only small amount removed originally, system appears not to require the full bleeding procedure).
Job Done – Enjoy the fully assisted steering experience – lol. Paul,
Post #523104 28th Jul 2019 8:30pm
Pawl
ADMINS :
With hindsight my posts above should probably belong in the Modifications & Maintenance (L322) section.
Could you move it please ? Paul,
Post #523112 28th Jul 2019 9:25pm
S.Hafsmo
Norway 2007 Range Rover Vogue TDV8 Orkney Grey
Great write up. Did you open the old power steering pump to see if there was an obvious problem? 2007 L322 3.6 TDV8 Stornoway
Post #523131 29th Jul 2019 6:09am
Pawl
Not yet, but will do in the next couple of days Thumbs Up
I'll update the post with any useful info. Paul,
Post #523146 29th Jul 2019 9:23am
great write up paul, put into the wiki.. Thumbs Up ... - .- -.
Post #523192 29th Jul 2019 3:19pm
Pawl
Thanks Stan.
It's good to be able to give something back for all the great info received from the forum !
I definitely wouldn't be running the RR without the forum Very Happy Paul,
Post #523197 29th Jul 2019 4:20pm
MarianaWestminster
Just to add to this, I replaced the pump today and on my facelift 2010 MY car the hex head on the auxiliary belt tensioner was a 21mm.
Also do not buy a laser branded viscous fan spanner (as sold in halfords etc) far too much flex in it meaning the hammer blows were just bouncing off.
I ended up using an adjustable spanner that just about fit in the available space.
Post #533768 10th Nov 2019 9:55pm
Pawl
Can an Admin remove this post for me please ?
Posted in error, before spotting a related post. Paul,
Post #533769 10th Nov 2019 10:31pm
ballast
United Kingdom 2008 Range Rover Vogue SE TDV8 Java Black
This is a really great write up - many thanks.
My MY08 was also 21mm tensioner.
The write up had prepared me for the 'hidden' 10mm, but actually, with a mirror, it wasn't too bad. What I wasn't prepared for was the battle with the n/s hard plastic to flexi pipe connection and then getting it out was tricky. I refitted it before putting the new pump on.
One other point, I fitted a new pump which didn't come with the front and rear brackets and the bolts are inaccessible on the front because of the pulley wheel. To remove the front bracket I ended up angle grinding a gap in the old pulley to give access to the bolts!
On the whole not lots of fun, but not too bad; obviously power steering fluid absolutely everywhere!
Chris
Post #695388 2nd Jul 2024 9:06am
MarianaWestminster
Ballast,
How did you re fit the brackets to the new pump?
Also what were your symptoms?
Got this job to do soon and I've also bought a pump without the brackets.
What make is your pump?
Thanks,
MW
Post #695390 2nd Jul 2024 10:52am
ballast
Symptoms were excessive noise, not quite screeching, but close, certainly squeaking.
Re the brackets, on the old one, I couldn't get the pulley wheel off the spindle, so simply cut a slot in the pulley wheel so I could get to the bolts securing the bracket - easy once you can get to them.
Only affects front bracket, rear bracket is accessible.
On the new pump (I went Meyle) the pulley wheel is secured with three nuts, so easy to remove, fit the bracket and replace the pulley wheel.
Hope that helps
Chris
Post #695398 2nd Jul 2024 12:30pm
MarianaWestminster
Thanks Chris,
The info is a big help.
From what I recall from when I changed the pump on a previous 322 (with a used pump that already had brackets) the pulley wheel has holes in its face.
I assume the bolts cannot be accessed through those necessitating cutting the slot?
I've bought a eurospare pump, hope that has a removable pulley wheel!
Thanks
Post #695404 2nd Jul 2024 1:16pm
ballast
Correct, sadly you can't get access through the holes.
You may be able to undo it with an Allen key on the spindle, but I couldn't budge it.
Post #695430 2nd Jul 2024 7:57pm
MarianaWestminster
What a pain, I thought maybe that's what the holes were for but maybe it's something to do with balancing/lightening the pulley wheel?
I've read the workshop manual and it says the pulley wheel is pressed on, that might be why you had no luck with the Allen key.
Hoping this pump replacement brings better results than the previous 322.
This one's just a project bought cheap to do up.
Post #695434 2nd Jul 2024 9:41pm
