Home > Maintenance & Mods (L322) > Is it worth bothering using IID to switch on DRLs?
M@r]{
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Barolo Black
From a safety point of view I am a fan of DRL's. Especially now most cars have them, so other road users get used to seeing them before pulling out etc, so those cars without DRLs are more at risk of not getting noticed at that quick glance.
I've been reading / searching on here for info on this, discovered you can switch the LED side lights to a DRL funtion via the IID tool. However, are they any good? Are they standard sidelight brightness? Because in daylight that probably isn't bright enough.
I will buy one of these tools, but could do with waiting a little while before I do. But if these are worth switching on I'll buy sooner.
Thoughts / experiences?
Post #533687 10th Nov 2019 9:44am
because you havnt filled in yourcar profile i gather you have a 2010~2012 year..
the fairy lights are not very bright and i think its better to convert the fogs to leds and install a drl switch.. ... - .- -.
Post #533688 10th Nov 2019 9:51am
M@r]{
Yes sorry, I only put a deposit down yesterday (after lurking on here for a short while) I'll update that info next
That's a shame. I did notice some of these. Really don't want them to look aftermarket though, which I think these might.
https://www.powerfuluk.com/vehicles/range-...ype-2.html
Post #533689 10th Nov 2019 9:55am
Brian Considine
Personally, I think those in the link will look a bit "Halfrauds".
I have a 2003 Vogue L322 that I would like to use the front fogs as DRL's - I don't want to change the lights in any way as they are not too bad as fogs.
Is is possible to use them as such without interfering with the bulb monitoring or are they not monitored ?
(Could easily be hard wired using a couple of relays & diodes). 2003 Range Rover Vogue TD6
Post #533691 10th Nov 2019 10:04am
@mark, those are nice and bright and i believe cam-tec-craig had them on his L322..i fitted halo types which were much cheaper.. ... - .- -.
Post #533716 10th Nov 2019 3:01pm
No Stan, i had the Osram equivalent, much the same but pricier! Whistle Thumbs Up
https://www.powerfuluk.com/range-rover-spo...l-fog.html
Post #533725 10th Nov 2019 5:30pm
Superspoons
I've enabled it on mine - looks fine and any extra light is better then nothing. Gavin
Post #533731 10th Nov 2019 6:14pm
I completely agree with you sir... Far better than nothing! At least you will be seen on a B road when your under trees 👍
Post #533737 10th Nov 2019 6:46pm
my fairy lights wernt very effective,
Mr. Green ... - .- -.
Post #533748 10th Nov 2019 7:17pm
brian1951
2012 Range Rover Westminster 4.4 V8 Orkney Grey
Totally agree, CTC did mine Thumbs Up
Post #533752 10th Nov 2019 7:23pm
Baltic Blue
I enabled them on mine, fronts only, but have I dreamt that their is an option to enable fronts and rears on 2011’s ??
Norway setting or similar?
If so I would be tempted to change them, particularly for the winter months when I often find myself switching the sidelights on during daylight hours due to poor weather conditions.
Post #533758 10th Nov 2019 7:44pm
GGDR
Whilst I have my 'fairy lights' switched on, I quite like the idea of DRL's in the fog hole (!)
The powerfuluk ones linked up above have a weird light shape, couldn't find ones (with the 4-bolt fitment) with ring DRL outer and fog interior.
Thought that would look good if I could find ones like that. Cheers, Greg
Post #533762 10th Nov 2019 8:04pm
M@r]{
They do have a few other styles:
https://www.powerfuluk.com/vehicles/range-...e-499.html
https://www.powerfuluk.com/vehicles/range-...e-500.html
https://www.powerfuluk.com/vehicles/range-...ype-5.html
The last ones are like you describe I think?
Post #533764 10th Nov 2019 8:12pm
@greg, i have a thread somewhere showing how to fit cheap eBay halos...
edit, https://www.fullfatrr.com/forum/topic33047.html?highlight=drl ... - .- -.
Post #533765 10th Nov 2019 8:15pm
GGDR
Thanks chaps. Thumbs Up
Not keen on the ebay ones Stan.
Yes the third powerfuluk link looks about right (thanks).
Unfortunately out of stock. Cheers, Greg
Post #533766 10th Nov 2019 8:23pm
