![]() | Home > Technical (L322) > Coding ABS module |
tveitan Member Since: 10 Dec 2016 Location: Norway Posts: 47 ![]() ![]() ![]() |
Sounds strange.. Are you able to read the coding file using the command codeiren_lesen? 2002 Range Rover Td6 |
Loyola1988 Member Since: 04 Mar 2019 Location: PARIS Posts: 8 ![]() ![]() ![]() |
hello can you sen the L30 file? Where can i download it?
found it thanx |
It was unfortunate that my solution didn't work for you. At least the lights in the dash is gone, which is always a pleasure |
HELLO
Sx200 Member Since: 09 Nov 2018 Location: Gold Coast Posts: 5 ![]() ![]() ![]() |
hello can you sen the L30 file? Where can i download it? |
Hi. Pm me your email and i"ll send you the file 2002 Range Rover Td6 |
Thanks I managed to find the file, can't get tool32 to work though!!! |
