Home > General > Late L322 or early L494
Clfno1
Looking to get back into a Range Rover after previously having a 54 reg 4.4V8 and was wondering what would be considered the safer, more logical option in terms of reliability and usability; late model L322 4.4TDV8 or an early L494 Range Rover Sport 3.0 SDV6? I looked at late model Discovery 4's as well but I have near enough talked myself out of that one!
Budget is up to around £27-30k, but obviously if the better option is cheaper then all the better!
Cheers guys
Post #533317 6th Nov 2019 1:38pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
This the Full Fat Range Rover site Sir , question answered Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #533319 6th Nov 2019 1:47pm
Clfno1
If it were the old model Range Rover Sport (Discovery in drag) then it would be a done deal, but with the new Sport being Range Rover based it did muddy the waters a little.
Can you give some information to back up the recommendation please?
Post #533343 6th Nov 2019 5:41pm
Discotigger
With a budget of £27 - £30 k, I would personally be looking at an L405 Range Rover.
A Range Rover is a Full Fat 4x4, a Sport is a...well, Sport...NOT a Range Rover, Just as an Evoque is... Censored
Just my opinion though! Rolling Eyes
Post #533345 6th Nov 2019 6:09pm
Clfno1
£16-20k gets a good late model L322, whereas £27-30k gets a 4.4 L405, is the new model really worth £10k more for a car only a year or two newer?
Post #533363 6th Nov 2019 9:02pm
Red Merle
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
@Discotigger - Absolutely Thumbs Up There are several V8 ‘405’s available within that budget, such as:
https://www.greenlightmotors.co.uk/used-ca...site-visit
If it’s a choice between the SDV8 and an SDV6, the ‘8 has a reputation for longevity.
Post #533364 6th Nov 2019 9:03pm
Red Merle
Why did you “talk yourself out of” a late Disco 4? There’s a lot to be said in their favour Thumbs Up
I don’t know enough about the L322 to know if it’s worth spending another £10,000, although the later car is made of aluminium and should be fairly corrosion resistant Thumbs Up
Post #533365 6th Nov 2019 9:11pm
Clfno1
I don't know, I get the fact that they're huge, and for the family that is a good thing, and for the money you can get a decent 14/15 reg for £20k, which is a lot of car for the money. But I just think it may end up feeling a bit too big and heavy, not quick enough and the reliability of the engine is a worry... Again the plus side is I'd never drive it like I stole it and would adopt a more laid back driving style less likely to get any points. Drive the car like its intended...
Post #533368 6th Nov 2019 9:46pm
Discotigger
Up until two weeks ago I drove an MY05 Range Rover TD6, thought it was a great car (recently retired on 314,700 miles! Check out the mileage thread on here for proof!) and just upgraded to a 2012MY 4.4 TDV8. Holy cow!! the difference is unbelievable, and if I'd had a bigger budget I would have gone for a L405. They're a newer model and will have better aftersales parts, service, etc. (companies prefer to make good cheap parts for newer cars, the 'oldies' become less cost effective).
Why do you think this forum now has a separate section for the L405 models?
Again just my personal thoughts. Thumbs Up
Post #533370 6th Nov 2019 10:26pm
The law of diminishing returns applies of course, but typically the more you spend the better the experience you'll have. Only you can decide what level is "enough" for you and any more is just egging the pudding. Depreciation will be your biggest cost no matter which you buy. As has been said, the L322 vs the old Sport was chalk and cheese. I've not spent any time in a 494 so cant be so sure - particularly vs a 322, but I'm confident a 405 will better than a 494 - they actually manage to sell them for £40k more after all. And I don't get your notion that a FF wont be "quick". My 5.0SC isn't quick like a Lotus is quick, but there's not many barges on the road (including the Sport) that do high speed cruising as well. Indeed straight line acceleration on motorway slip roads and the like can be real "doors to manual" moments if you so choose and/or the occasion demands. Mike - MPx
Post #533373 6th Nov 2019 11:21pm
Clfno1
My reason for discounting a Discovery 4 was that it wouldn't feel quick, and one of the reasons to go for the 4.4 L322 or the Sport was that it would have a bit more shove, sorry for being ambiguous.
Late models generally have a reputation for being more reliable than new models as all the links have been ironed out and was wondering if that was the case here. Having had a look, there are quite a few L405's, either with the SDV6 or the SDV8 around, and that's really tempting me now.
Extra performance against the extra economy and cost is now a question, as is the engines reliability...🤔🤔
Post #533380 7th Nov 2019 6:06am
Red Merle
From what you’ve said, stick to the SDV8. The aluminium bodied cars are substantially lighter and will really help with straight line performance too.
Do you need the outright space, high up driving position and split tailgate? If not, could the L494 Sport better suit what you’re looking for?
Post #533382 7th Nov 2019 7:19am
kooky_guy
Well the SDV6 3.0 has a bit of a reputation for self destruction.... 2010 4.4 TDV8 Vogue SE
Post #533383 7th Nov 2019 7:42am
Clfno1
It's more the reliability of the engines that is my concern now, some say the SDV6 run fine and have no problems, others say the engine can seize and destroy itself, and it seems quite even to those with and without problems...
Post #533391 7th Nov 2019 9:17am
Red Merle
Not only is the crank rock solid in the 8, but it runs massively over engineered cam chains and gears, in place of belts. The belts will be up for change on any SDV6 ‘405 of that age as well.
With credit to Fleagle_UK for the original picture Thumbs Up
Post #533393 7th Nov 2019 9:33am
