![]() | Home > Maintenance & Mods (L405) > Goodbye L322 Vogue hello L405 AB |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16341 ![]() ![]() ![]() |
PF Jones... |
Flyingfocrs Member Since: 18 Oct 2016 Location: On the croft with the horses Posts: 93 ![]() ![]() ![]() |
Thanks i’ll look at those.
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2688 ![]() ![]() ![]() |
Had a detachable fitted a few months back, was around £800 all in , plus another £30 odd quid for a replacement under bumper panel |
So a quick update.
Statler Member Since: 22 Jun 2019 Location: Leeds Posts: 29 ![]() ![]() ![]() |
Had similar problems with the suspension, I was initially fobbed off with a software upgrade however it turned out to be the compressor, now it’s been replaced it’s working perfectly. |
brad s1 Member Since: 23 Sep 2008 Location: Boston Posts: 134 ![]() ![]() |
do you know how the fixed the transfer box problem? I'm assuming the judder? I have this and really need to set some time aside to carry out the TSB which is a double flush of the box as far as I can tell. |
The first issue with the car going into extend mode when access mode selected was apparently down to a drain valve on the compressor so suspect fixing one issue has created another as they carried out a bulletin fix on the valve. Just dropped car off so will see what they say. |
Yeah, when it shoots up after a command for lowered stance that has to do with the compressors exhaust valve. It attempts to lower but cannot vent air quickly enough so it raises back up. On the l322 you'd remove the exhaust silencer and drill a small hole in it for the fix vs a new exhaust silencer which will just clog again in time. I'm sure the l405 is similar.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6773 ![]() ![]() ![]() |
Tell me more about this please, as I think I have this problem.
Yes in order to lower there is a brass filter on the compressor where the air discharges. If it becomes clogged air cannot leave the system quick enough and the car rises. This is what would happen on an l322 but given it is the same situation I'd imagine similar root cause. I do not know if the l405 has a similar exhaust silencer or some other component but I'd bet whatever is between air leaving the system and the atmosphere is probably the cause.
I have an error on my l322 about the compressor not being able to get rid of the air quickly enough. All I get is “suspension fault, standard height only”. Got - 2017 SDV8 Autobiography in Loire Blue
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7916 ![]() ![]() ![]() |
https://www.fullfatrr.com/forum/topic23038-45.html
A known issue there is a service bulletin about it. https://www.fullfatrr.com/forum/topic50351...n+bulletin When pulling away with lock on it feels like diff is locked and noise from rear. Fix is change oil, software update, road drive and then change the oil again. |
Yeah I saved that TSB and have the fluid for double flush on the shop bench, just need to do it. As for the reprogramming I guess if the flush doesn't remedy the issue I'll take it in for an update post flush. |
