Home > In Car Electronics (L322) > Rse screens
Danwilderspin
Rse screens
Hi all,
One of my rse screens has been damaged since I had the car (a wood incident I think) anyway no bother as I only have one little one...
So the other has been working fine but today I just have a white screen when it’s on - any ideas?
My first port of call was to swap the screens to check the wiring but I don’t know how to open the headrests you - any ideas? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #533040 3rd Nov 2019 12:02pm
rjff
Try finding the connections under the seat and see if they have dislodged, not unkown, and/or need cleaning. There's also a thread somewhere on here that I understand Cam Tech Craig wrote about replacing the screens but can't find it at the mo.
Look to see if you can remove any surround on the screen, it should just clip on/off with care along with the headrest cover to access it. There may be a connector in there.
Looking at the WM it appears the cable to the screen routes up the back of the seat, through the headrest pillar and to the screen. All sorts of gumpff about making sure the SRS is deactivated etc. so taking the whole thing out is a pain. Cheers
Richard
Gap IIDBT
Post #533072 3rd Nov 2019 8:01pm
mjdronfield
Are they factory RSE screens or aftermarket?
Wiring routing may not be exactly the same.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #533073 3rd Nov 2019 8:36pm
Danwilderspin
Thanks guys - they are genuine rse - it looks like (on eBay used screens) there is a plug on the screen hence why I want to swap side to side first if the covers pop off so I will start there and report back! Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #533075 3rd Nov 2019 9:10pm
rjff
good luck Thumbs Up Cheers
Richard
Gap IIDBT
Post #533076 3rd Nov 2019 9:14pm
Danwilderspin
Swapped the screens still just white guessing its Censored - I will try fiddling the cables first but if they are both broken this is the push I may need to dump the current ice and fit a new stereo as I have a plan but unfortunately it doesn’t involve rse Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #533473 7th Nov 2019 11:01pm
