Home > Technical (L322) > 4.4l v8 diesel starter motor not working |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3772 |
It sounds more like a dodgy battery terminal connection after you have fitted the new starter motor.
28th Oct 2019 3:16pm |
ozzy22 Member Since: 16 Oct 2019 Location: Glasgow Posts: 20 |
Thanks Mike. I did double check them and ran sand paper over both the terminals on the battery and on both the positive and negative leads. |
28th Oct 2019 7:15pm |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 360 |
Currently experiencing the dreaded click, out of interest what make of replacement starter? 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
28th Oct 2019 8:37pm |
Their is one old post on here where someone reported that the lead from the battery down to the starter was faulty.
28th Oct 2019 8:55pm |
So another night under my pride and joy. The starter I bought is just off fleabay. The brand is aapolham. It comes with 12 month warranty and was £134 shipped.
29th Oct 2019 10:15pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2485 |
I suggest that you replace the starter relay (6E - engine bay fuse box). |
29th Oct 2019 11:13pm |
Thanks for you reply Graeme. I swapped the relay over with the heated windscreen one I think it was as it is the same. That didn't help. |
30th Oct 2019 6:58am |
If anyone knows of a good Indy around the Glasgow area could they please PM me?
30th Oct 2019 10:44am |
The thread in the Wiki for replacing the 3.6 starter mentions that the wire from the starter relay to the solenoid on the starter motor needed to be replaced due to excessive voltage drop. Was your 8.5V measured while trying to start with the new starter when there was load on the wire? |
30th Oct 2019 11:24am |
Yeah it was 8.5v with load on it.
30th Oct 2019 11:42am |
I did cut the end off that ignition wire last night thinking if it would be corroded it is probably most likely and the bottom where it is exposed to more salt and moisture. It looked fine and I soldered a new end on but maybe its further up the wire..... |
30th Oct 2019 11:49am |
The relay is only to power the starter solenoid although it may take a circuitous route.
30th Oct 2019 7:49pm |
Thank you for your reply and advice Graeme. I will update once I get a chance to change the ignition wire. |
30th Oct 2019 8:00pm |
The wiring schematic shows for the wire run:
31st Oct 2019 8:05am |
