Home > Technical (L322) > MY 2011 - LED Trailer Lights?
TJRL
United Kingdom 2011 Range Rover Autobiography TDV8 Baltic Blue
Just fitted a tow bar and electrics to my RR and all is good when connected to a trailer board with filament bulbs. But when connected to a LED trailer board the RR does not recognise that there is a trailer attached and so the parking sensors remain active and the cars fog light's still light up with the trailer's ones.
I know that this is down to the lower draw of LED versus filament bulbs, but there must be a way to get this to work without the need to fit ballast resistors into the board. After all any new tin tent will have LED bulbs for sure.
Is there a fix anyone can point me to?
Many thanks in advance. Thumbs Up 2010 Range Rover TDV8 Baltic Blue Autobiography (2011 MY) - SOLD Sad
1960 Land Rover SII SWB SW
2020 BMW R1250 RT LE
2021 Triton ST-125 (Monkey Bike)
Post #532596 29th Oct 2019 9:46pm
heres one thread re this,
https://www.fullfatrr.com/forum/topic38077...ler+lights
there are many more relating to this problem, do a search Wink ... - .- -.
Post #532599 29th Oct 2019 10:03pm
GDM
United Kingdom 2006 Range Rover Vogue Td6 Zambezi Silver
Re: MY 2011 - LED Trailer Lights?
Unnecessary quote removed
That is very odd. Our 2006 MY, which has a genuine LR tow-bar wiring kit fitted, works fine with a trailer with LED lights.
Post #532602 29th Oct 2019 10:31pm
If it helps? The car knows the trailer is connected only through the brake light circuit so, you only need a resistor or filament bulb on that circuit sir Thumbs Up
Post #532603 29th Oct 2019 10:51pm
TJRL
Cam-Tech-Craig, Thanks for that info, as a last resort that offers a simple bodge solution.
Thanks also to Stan, I tried searching first, but like you did not find a thread with a solution to the issue, but then again it may be there but beyond my searching capabilities!
Thanks both. 2010 Range Rover TDV8 Baltic Blue Autobiography (2011 MY) - SOLD Sad
Post #532606 29th Oct 2019 11:42pm
Brian Considine
It seems that LED's/bulbs/RR's is a bit of a "black art" - what works on one vehicle/trailer may not work on another.
I have LED''s on my box trailer - the basic rear clusters are doubled up so the brake light LED's draw enough to keep the car brake light monitoring happy.
Although the sidelighs are supplemented with side marker lights I sometimes get a "check trailer light" warning, sometimes not.
However, until I fitted load resistors to the indicators they were very erratic. 2003 Range Rover Vogue TD6
Post #532621 30th Oct 2019 8:51am
