Home > Technical (L322) > trim at bottom of tailgate glass
tsadpt
Hi everyone! I have searched for this but to no avail... the black trim on my 04, between the top of the metal bit of the upper tailgate and the bottom of the glass, is off centre; I have had the car for a year, and its really annoying me now!!! does it just pull off with brute force, or does it need to be levered with a thin tool underneath? I dont really know where to start with this trim piece, and I am scared of bending it if it starts to pop off!!
Ta!
David
Post #49524 9th Feb 2011 10:46pm
InVogue
Not sure which bit you mean - inside or outside?
Post #49546 10th Feb 2011 12:28am
dan_uk_1984
When you do figure it out, please let me know!
I've tried pushing mine along back to the middle, but it doesnt want to go.
Post #49566 10th Feb 2011 10:13am
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Me too.
Tempted to just break out the Dremmel and cut the protruding side off!
Post #49582 10th Feb 2011 12:07pm
Think its wedged under the glass so best left alone.
Interestingly on later models they stopped fitting it, mine doesn't have it but my TD6 did, then they started fitting it again. Go figure. Discovery 4 HSE
Post #49681 11th Feb 2011 10:07am
VMPP
Portugal 2007 Range Rover Vogue TDV8 Buckingham Blue
The newer cars still don't have it. They stopped using it during 08MY. Now they just have a very thin plastic, just to give it a better looking finish.
What you can do, is give it a few wacks with one of those plastic hammers so that it goes back to the center. But it will inevitably go back to being off center. On my car that piece is already leaning into the C pillar...
Post #49686 11th Feb 2011 10:43am
SteveMFr
Site Sponsor
I tapped mine with a rubber mallet - went right back. It moved out, so it has to move back...
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #49701 11th Feb 2011 12:55pm
ogy
United Kingdom 2003 Range Rover Vogue Td6 Bonatti Grey
this trim can be removed. just lever out one end and pull. i removed mine to paint the tailgate then pushed it back in. i put some washing up liquid on it to help it slide back under.
Post #49826 12th Feb 2011 10:51am
p38arover
Australia
Thread resurrected from the grave.
Do you mean item 2 - DCD000011PMD?
Mine is breaking up badly and I want to replace it. I'm not sure how hard it is to remove.
I'm tempted to remove but not replace it.
 Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #532520 29th Oct 2019 7:26am
p38arover
Australia
I just found this (from a link on rangerovers.net Smile )
https://www.fullfatrr.com/forum/post280195.html
And this pic from bebechoon's gallery:
 Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #532521 29th Oct 2019 7:36am
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Easy done, I removed mine as soon as i got the car. Tapped mine sideways using a piece of wood to keep the hammer away from the glass. Lots of wd40 or simmilar. Probably could be tapped downward but I was concerned of the glass. Dont replace it, its much better without 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #532523 29th Oct 2019 8:24am
p38arover
Australia
Done. It took a bit of persuading but once it started to move, it moved relatively easily. When there was about 200mm protruding, I was able to grip it by hand and pull it out.
I'm not sure that I like the big gap, though. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #532526 29th Oct 2019 9:39am
wayneg
Its an upgrade to later spec, move with the times Wink It must be the only free update available 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #532536 29th Oct 2019 12:37pm
p38arover
Australia
LOL!
I'll have to check out a later car. Surely the rear glass would be longer to hide the big gap? Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #532537 29th Oct 2019 12:47pm
wayneg
A complete win for LR, weight saving, money saving and put they price up, Same glass. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #532549 29th Oct 2019 3:08pm
