![]() | Home > Maintenance & Mods (L322) > rear wishbones and subframe bushes |
RichM63 Member Since: 10 Jul 2019 Location: Brittany Posts: 249 ![]() ![]() ![]() |
Check the 'Rose Joint' bushes in the 'hub Knuckles' they are likely to be "SHOT", (dismount the knuckle assembly and 'waggle' the bushes by hand. |
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 ![]() ![]() |
the hub bushes (top and bottom) were replaced recently along with drop links and tie bars.
The upper wishbones and EPB cables are a bit of a pig.
are you not removing the rear subframe - i think this would make accessibility much better |
That would imply that we had a plan. |
