![]() | Home > Maintenance & Mods (L322) > L322 3.6 tdv8 oil leak |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4321 ![]() ![]() ![]() |
Could be a number of things. Some on here trying to find leak sources 12 months in! |
seany150 Member Since: 30 Nov 2015 Location: Wareham Posts: 9 ![]() ![]() ![]() |
It's definitely coming from this shaft, I cleaned it all up. Moved car forwards and backwards and checked again and it was wet again so leaking out on rotation. I'm hoping someone may have had same issue and can tell me it's a simple 10 min fix
Take it to Evans Garage up the road from you. Highly rated. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
so the car passed the mot yesterday, got an advisory on this oil leak so keen to have a go myself now I'm not rushing to get it done to mot deadline. has anyone any firsthand experience how to go about, how complicated is it?
First photo looks like oil higher up... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Nick591 Member Since: 04 May 2017 Location: Seaton Dalaval Posts: 193 ![]() ![]() |
If its leaking down the bell housing it may be coming off the V between the cylinders which indicates a problem possibly with the oil filter housing/fuel cooler assembly. Mine has had this leak for over a year but the leak on mine is really small so I haven't got round to fixing it. Its a relatively big job to get at the assembly to inspect or replace. On mine it doesn't drop oil when parked and fortunately doesn't leak onto the exhaust or the driveshaft. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8 |
