Home > Technical (L322) > Is the rear spoiler adjustable at all?
dazza1983
For those in the know I had water leak fixed by dealer and then the tailgate was not aligned properly so last week they re aligned the tailgate but the spoiler is not even gap both sides and also one side the spoiler is sat back from the roof curve instead of being flush? Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #532295 27th Oct 2019 2:45pm
There is probably a little bit of side to side/back and forth adjustment once you loosen the bolts. You will probably break some of the clips when removing the inner tailgate trim though... .
Post #532299 27th Oct 2019 3:29pm
gilesharrison
United Kingdom 2008 Range Rover Vogue TDV8 Stornoway Grey
Yes. There's quite a bit of movement in it. Takes a bit of trial and error to get the alignment correct.
Post #532309 27th Oct 2019 4:47pm
dazza1983
Ah that’s good to know. Thanks guys.
I was worried that it was a fixed alignment as there is fixed slots it slots into right?
If that’s the case it may be better for me to adjust it rather than Land Rover with there track record. Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #532321 27th Oct 2019 5:39pm
DrRob
I did mine recently when I installed a new high level brake light Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #532325 27th Oct 2019 6:06pm
dazza1983
Can you confirm there is adjustment left right forward and back mate? Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #532329 27th Oct 2019 6:15pm
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
I’m no expert, but you don’t need to remove the plastic trim to adjust the spoiler Joe? 2014 vogue se
Post #532344 27th Oct 2019 8:29pm
dazza1983
ill hold fire then untill confirmed.. Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #532351 27th Oct 2019 8:58pm
Mr Tee
Yup, no need to remove plastic inner, bolt access easy enough with a socket
Post #532353 27th Oct 2019 9:20pm
dazza1983
Care to share the knowledge buddy?
I want to move spoiler a touch to the left and forward a little one side. Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #532355 27th Oct 2019 9:27pm
Nick591
Open upper tailgate fully. Look between upper window trim and body. You will see 3 galvanised head hex bolt heads, one in centre, one each side. Loosen them them to adjust spoiler until washer on each is loose. Close tailgate and grasp rear edge of spoiler to move in or out. For side to side you may need to combine with in and out to work it across. If you take out one of the bolts you can see the relative size of adjustment hole and threaded hole which will give you an idea how much you can move it in any direction. When you are done open the tailgate and tighten the bolts. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8
Post #532358 27th Oct 2019 9:42pm
dazza1983
Thanks for this.
Under what circumstances regarding the spoiler would you need to remove the inner trim? Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #532367 27th Oct 2019 10:07pm
You would only need to access the inner trim if you were removing the spoiler as the reverse camera and 3rd brake light wiring plugs are inside the inner cover...
If you only want to adjust it then as above, remove/loosen the three 10mm headed bolts and wiggle it around... That said, the spoiler is on two plastic sliding pegs fore and aft so im not sure how much sideways movement you'll get? Suck it & see im thinking Thumbs Up
Post #532373 27th Oct 2019 10:33pm
Nick591
In my experience only either to maintain/repair the rear wash/wipe motor and pipes, or to deal with aspects of the wiring if you need to replace the reversing camera with an aftermarket one.
The trim can be bit fragile where the fastening clips hold it in place. Sometimes the lugs break off. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8
Post #532374 27th Oct 2019 10:33pm
