Home > Technical (L405) > Steering wheel buttons stopped working
Ent
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
As per the title the left hand side only has stopped working. First to go was the volume up, all the rest worked now they have stopped. Anyone else had this happen?
Post #531876 23rd Oct 2019 12:30am
basil
2014 Range Rover Autobiography 5.0 SC V8 Mariana Black
I had the same issue with my volume up and down (RR AB 2014) and ask the dealer to replace the switch - They refitted the existing one and it sorted it for around two months, now its starting to go again.
Post #531939 23rd Oct 2019 10:01pm
brad s1
2004 Range Rover HSE 4.4 V8 Giverny Green
probably clock spring.
Post #532245 27th Oct 2019 12:31am
basil
Apologies if I am being thick, but I have no idea what CLOCK SPRING means?
Post #532361 27th Oct 2019 10:54pm
brad s1
it is the thing on your steering column and behind your steering wheel that allows connectivity between the cars electronics and the controls on the steering wheel/horn/air bags/heated wheel/ etc etc etc. When one goes bad certain functions will go on and off, it could be as easy as removing and giving a good clean, or it may need replacement.
When you reset things and they work, then stop again... replace switches/components only to have them work for a time and then not, generally the common denominator is the clock spring. You have to remove the air bag/steering wheel and possible some steering column covers to get at it.
Post #532381 28th Oct 2019 1:56am
basil
Thanks for explaining.
Post #532382 28th Oct 2019 2:23am
