Home > Maintenance & Mods (L405) > Retrofit Climate Control Unit from 2017 to 2015?
jpr993
United States 2015 Range Rover 5.0 SC V8 Indus Silver
Hello - have a 2015 L405 supercharged. One of my pet peeves is the access to heated and cooled seats through the screen. LR must have also realized this was annoying and changed it in 2016/2017.
With all the other talk of retrofits here, has anyone attempted to retrofit a 2017 control unit into a 2015?
I believe the 2017 part is LR086027. I was thinking that it could be as easy as plugging it in since it is all software underneath.
Any thoughts or has anyone tried this?
Thanks,
Jon
Post #532090 25th Oct 2019 11:43am
Charles89
United Kingdom 2014 Range Rover SVAutobiography SDV8 Scotia Grey
I also want to do this retro fit. According to a breaker I spoke to he seems to think the pannel shares the same mounting and plug for the wiring, so its possible that it may work
Post #532186 26th Oct 2019 3:17pm
Bora20
Canada 2013 Range Rover 5.0 SC V8 Santorini Black
The new unit is GLPH-18A802-DH.
I want to do this in my 2013, but I am not sure if it will work. Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #647432 5th Nov 2022 4:35pm
If it doesn't work I have one of these fitted, works very well, better than most aftermarket touch screens.
Can be configured for left or right hand drive... Heated/cooled seats in two presses from the default climate screen..
https://rangeroverworld.co.uk/shop/ols/pro...LM-RGH-HND
Unfortunately they do seem to be out of stock at the moment...! Pete
Post #647434 5th Nov 2022 5:06pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
There are a few Youtube videos on this easy changeover and just one plug that fits both units.
Post #647435 5th Nov 2022 5:08pm
RutlandBoy
United Kingdom 2015 Range Rover Vogue SE SDV8 Santorini Black
Re: Retrofit Climate Control Unit from 2017 to 2015?
Hi,
As other,s I've done it and it worked very well.
Just be careful that you get the right unit!
If the seller isn't sure or the label has been removed from the unit I'd steer clear - although you might like to check if the 'knobs' can be pushed in - a switch action - as (obviously) the original one doesn't have that switch action.
Here is the thread that I put up when I swapped mine.
https://www.fullfatrr.com/forum/topic63174.html
A worthwhile modification, easy if you take your time and have the right tools L405 4.4 V8 Vogue SE Santorini Black
RRS L390 4.2 S/C Stornoway Grey
Classic Range Rover Overfinch 5.7 - their first prototype - under restoration
Late Range Rover P38
Range Rover 3.9 Classic Softdash
Range Rover Classic Overfinch 5.7 - Sadly gone
Disco 3 - Gone
Disco 2 - Gone
TD5 - Gone
Post #647478 6th Nov 2022 10:24am
Tinman
From the other videos, I have seen I think it can also be changed to a 2018 model.
Post #647490 6th Nov 2022 1:12pm
