Home > Technical (L405) > Engine randomly stalls right after startup? |
brad s1 Member Since: 23 Sep 2008 Location: Boston Posts: 134 |
I'd have a look at the throttle body, in my experience anything supercharged ends up pulling garbage back through the intake via some breather and it settles around the blade of the TB. On cold start that garbage inhibits airflow and you'll stall or have loopy idle. I'm not sure where the TB is on the l405 but on the l322 it was on the back side of the engine which made access sort of annoying. Regardless find it (hopefully up font) pin the blade back and have a look. If there is trash all around the plenum behind the blade clean it.
22nd Oct 2019 8:44pm |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
Once it stalls does the display screen go in 4x4 mode ??? 2015 4.4 AB
22nd Oct 2019 10:51pm |
pherplexed Member Since: 27 Apr 2010 Location: SC, USA Posts: 69 |
No, screen just goes dark like I’ve shut the car off. 2021 P525 | Eiger Gray |
22nd Oct 2019 10:53pm |
Mark1107 Member Since: 19 Oct 2014 Location: Los Angeles Posts: 106 |
Disconnect your negative cable to the auto stop start mini battery or solenoid in the trunk and you won’t have to worry about it. |
28th Oct 2019 2:51am |
