Home > Maintenance & Mods (L322) > Brake Bleeding 4.4TDV8 - engine running?
SpitfireS
Germany 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Hello All,
Tomorrow I'm changing pads and I'm reading the workshop manual (again Wink )
And all of a sudden I see one must run the engine to bleed the brakes?
I've changed rotors and pads on other cars and never had the engine running.
It always worked fine.
Is the RR different in that the engine NEEDS to be running?
Just making sure.
Thanks in advance Smile
Post #531786 22nd Oct 2019 1:58pm
you dont have to bleed the brakes if you're just changing pads....theres a 'how to' in the wiki.. ... - .- -.
Post #531788 22nd Oct 2019 2:13pm
SpitfireS
To change old/thin pads to new/thick pads I need to open the bleeder to not push the old fluid up and back into the reservoir.
I'm opening the bleeder: Twisted Evil I'm bleeding Very Happy
The wiki from northernmonkeyjones is perfect!
Just asking for opinions / experiences about running the engine (or not) while bleeding as described in the workshop manual.
On other cars I've always gravity bled brakes as I usually work alone on my car.
It's a little slow but it works.
Smile
Post #531820 22nd Oct 2019 5:19pm
nino_nino
use vacuum, fast an easy/
https://www.fullfatrr.com/forum/topic44822.html 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #531825 22nd Oct 2019 5:48pm
Danwilderspin
If you wedge a block of wood on the brake pedal BEFORE you disconnect the caliper you won’t lose anything (if that’s what you are doing?) Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #531862 22nd Oct 2019 9:47pm
