Home > Maintenance & Mods (L322) > how can you reset service warning lights on L322 2010-2012?
Nylands
United Kingdom 2012 Range Rover Westminster TDV8 Zambezi Silver
Bearing in mind that an early oil change ie less than 15K miles may not appear.
Post #531423 19th Oct 2019 11:39am
rjff
I'll stand to be corrected, but I have an awful feeling it may need a diagnostics kit like the GAP IID.
Others may have further thoughts. Cheers
Richard
Gap IIDBT
Post #531426 19th Oct 2019 12:09pm
DrRob
Correct. Or a cheaper tool like the icarsoft lr2 Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #531428 19th Oct 2019 12:36pm
Nylands
Thanks then both. Last service done by an independent but not happy altogether so a diy oil change this year. Only 6K miles but the right oil and filter this time. I’ve got an icarsoft lr2 but yet to use it before so I will report back. Wondered if there was a trick such as bonnet up, door open etc.
Dave
Post #531497 19th Oct 2019 8:47pm
rjff
The bonnet up trick is part of getting the oil level reading up when cold. It,'s on here somewhere but it escapes me at present. If I find it l'll post a link. Cheers
Richard
Gap IIDBT
Post #531518 20th Oct 2019 9:25am
Nylands
Thanks Richard
Just trying to understand any alternatives as I read somewhere that unless it’s done within 1000 miles of actually needed it’s off to main dealer? Hopefully it be like the electronic hand brade and a case of do this and that in the cab.
Cheers Dave
Post #531520 20th Oct 2019 9:40am
rjff
Oil level cold check link
https://www.fullfatrr.com/forum/topic51542...eck+cheque
As DrRob says try your icarsoft and see if it works on a service
Good luckreset. Cheers
Richard
Gap IIDBT
Post #531532 20th Oct 2019 12:03pm
Nylands
Will do Richard. Have the oil etc if not the weather.
Cheers Dave
Post #531538 20th Oct 2019 1:38pm
