Home > LPG > Which spark plugs are best for LPG?
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
Which spark plugs has anyone found to be good or worth avoiding for use with LPG?
Thanks Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #531466 19th Oct 2019 5:57pm
dingg1
Just use the ones that are spec'd for the car, you gain nothing by buying specials for lpg ime
Post #531467 19th Oct 2019 6:06pm
Gsxr1250dave
As above standard plugs
Post #531470 19th Oct 2019 6:17pm
Dolphinboy
+ 1
Post #531496 19th Oct 2019 9:43pm
cass
I can't give a logical reason for it but when I did a lot of LPG work I always found that NGK plugs were better than anything else. It was common to find that a set of NGKs would work fine on a car that had misfires on gas with other plugs.
They also had a good wesite that would show their recommended plugs for an LPG converted car.
Post #531500 19th Oct 2019 10:12pm
Zebedee
NGK's website suggests the recommended plugs are BKR6EQUP, if you want an upgrade go for BKR6EIX and for LPG use LPG1.
I wonder what the difference is between them...
I've also heard that there is no need to go for LPG plugs as the standard ones are fine. Current:
Sold:
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
Post #531579 20th Oct 2019 8:47pm
cass
Standard plugs might be fine but why not use the NGK recommend LPG plugs?
Post #531641 21st Oct 2019 1:44pm
Zebedee
Ended up using Bosch 4 prong Platinum plugs - which seem to be exactly the same as the BMW ones that came out. Part number FGR7DQP or 0242236562.
Amazon had them for £6.22 each. Current:
Sold:
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
Post #533634 9th Nov 2019 5:04pm
TeeMyob
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
Hi.
We have just had an Old Toyota Previa converted to LPG.
The guy who did the conversion, who has been carrying out installs for over 30 years. He told me to stick to standard plugs (which we had just changed anyway).
We have driven it to Javea in Spain from Manchester (via Santander Ferry). No issues other than getting stung at 80p a litre for LPG in Portsmouth. Should have put petrol in instead as it was 60p a litre in Bilbao.
No issues driving around Javea when we got there. But only covered around 1,000 miles on GPL so-far!.
Post #536371 4th Dec 2019 5:10pm
