Home > Technical (L322) > Boost /turbo issue |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3523 |
Welcome to the forum Mark
19th Oct 2019 2:45pm |
Mark williams Member Since: 19 Oct 2019 Location: Usk Posts: 7 |
Thank gdrr
19th Oct 2019 3:33pm |
Apologies for the typos
19th Oct 2019 3:35pm |
Yep the codes would help. But sometimes (like my post above) they don't always give you the right steer.
19th Oct 2019 3:52pm |
Thanks GGDR
19th Oct 2019 3:58pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16230 |
Welcome Mark, have you recently tried reversing up a steep hill? You can provoke a high level of turbo waste gate chatter that way!
19th Oct 2019 4:06pm |
Hi Craig
19th Oct 2019 5:06pm |
Would the secondary turbo valve cause this or a boost solenoid or something of this nature |
19th Oct 2019 7:29pm |
Definitely needs the codes reading/further diagnostics running... |
19th Oct 2019 8:43pm |
Finally packed in ,turns out the turbo actuator has failed and was jamming tehwastegate closed,
8th Nov 2019 2:25pm |
