Home > Technical (L322) > Whining noise in passenger footwell area 4.4 v8 L322 vogue
Granno50
United Kingdom 2011 Range Rover Vogue 4.4 V8 Adriatic Blue
Well for the past few months with one thing and another I have had a few issues done on my RR, with limited performance and high pressure pump and leaking oil cooler gaskets.
I still have an odd burning smell from time to time but it was this noise bothered me most.
On this forum there was a topic about the bottom intercooler pipe fitted between the intercooler and the turbo passenger side.
After some investigative work I removed wheel and right up near the turbo I can see it but god knows how I get to remove it and check it, it has signs of sticky oil residue around it and the noise seems to be coming from it.
My question is does anyone have some super sonic ideas how to remove it and replace it.
Part number I believe is the LR029007
Thx in advance
Paul
Post #531416 19th Oct 2019 11:32am
rjff
Paul
Sell the FF and buy a Volvo (see Joe90 Smile ) and anyway most whining noises come from the passenger seat, divorce helps with that. Mind if you've got her trained into the passenger well you're on a winner.
Serioiusly there's a workshop manual in the Wiki and if you continue searching then you will find someone has done the job. Also are you sre all the old oil from the leaking oil cooler gaskets has been cleane off? Perhaps a good place to start. Oh, and was the small oil pipe in the rear of the block near that fitted with new O rings?
When the car is cold in the morning can you hear the whine and does it go on for a few moments if you shut down the car and listen? (berfore you drive off) Cheers
Richard
Gap IIDBT
Post #531422 19th Oct 2019 12:09pm
