Home > Maintenance & Mods (L322) > How to change those pesky $%^& rear calipers on a TDV8.
goldsax
United Kingdom 2011 Range Rover Vogue 4.4 V8 Ipanema Sand
having read other threads and watched you tube videos non has mentioned the hand brake.
can i presume that no reset has to be done?
as i am thinking of changing disk this weekend.
thanks 2011 4.4 TdV8 Nara Bronze
Post #205012 20th Aug 2013 9:53pm
GGX
United Kingdom 2012 Range Rover Westminster TDV8 Fuji White
Make sure the hand brake is off, and you might have to manually back them off to, I think it's like the BMW set up where three is a star/spline to be rotated through the lug/wheel bolt hole rotate the disc to see it.
use a flat head screwdriver to rote until the disc can be removed.
Euro car parts had a 30% off offer pagid is good stuff.
Post #205029 21st Aug 2013 5:43am
it is similar to what goldsax says there is an observation hole on the disc, you use a screwdriver to move a star shaped adjuster to back off the handbrake pads from the hub, then pull off and refit new ones.
However according to rave you have to:
"1. Using the Land Rover approved diagnostic system, drive the parking brake to the mounting position."
whatever that means......
to adjust after changing:
1. Check operation of the electronic parking brake.
2. Release the electronic parking brake.
Press the brake pedal and press the parking brake switch down to release the parking brake. Check that the warning light goes out.
3.Turn the ignition key to position '0' and remove the key.
4. Remove the rear wheels and tires.
5. Remove the parking brake shoe adjuster access plugs.
6. NOTE: Rotate the rear brake disc to locate the parking brake shoe adjuster.
Rotate the parking brake shoe adjuster until resistance is felt and the rear brake disc will not rotate.
 Apply and release the parking brake several times to centralize the parking brake shoes, re-adjust if required.
WARNING: Do not work on or under a vehicle supported only by a jack. Always support the vehicle on safety stands.
Raise and support the vehicle.
7. NOTE: Rotating the parking brake shoe adjuster backwards will move the parking brake shoes away from the parking brake drum.
Rotate the parking brake shoe adjuster back 8 clicks.
8. Repeat the above procedure for the other side.
9. Install the parking brake shoe adjuster access plugs. 10. Install the rear wheels and tires.
 Tighten the wheel nuts to 140 Nm (103 lb.ft). There is nothing that can't be fixed with a hammer😜😜
Post #205138 21st Aug 2013 6:05pm
goldsax
Thumbs Up 2011 4.4 TdV8 Nara Bronze
Post #205163 21st Aug 2013 8:58pm
goldsax
procedure performed on a RRS but it all shows how to deal with hand brake adjustment as Northernmoneyjones has written in previous reply... 2011 4.4 TdV8 Nara Bronze
Post #205566 25th Aug 2013 5:20am
Danwilderspin
If you have 22s wheels don’t even need to come off! Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #531329 18th Oct 2019 3:17pm
