Home > Technical (L322) > New compressor suspension won’t drop
S700TNG
England 2007 Range Rover HSE TDV8 Java Black
Hi so a friend fitted a new Compressor and relay today to his 2003 range Rover it will go up but then will not drop until driven over 30 miles an hour
Any ideas
No fault codes
Post #531140 16th Oct 2019 4:37pm
You mean it will not come down from Off Road height using the dash buttons ?
Are the dash lights on (for the EAS) ?
Can you go to Access height then back to normal ?
Have you turned the steering wheel from lock to lock a few times? .
Post #531141 16th Oct 2019 4:42pm
S700TNG
It Won’t go from normal to Access
lifts to off road nice then the front stays up When dropping to normal
if driven over 30mph it drops to normal as it should
We have tried the steering from side to side but still the same
You can hear it vent the air when trying to go to access but the rear only drops 1/2 inch
It was ok before up and down but very slow then had suspension inactive come up on the dash
So ordered a new compressor from LR spares
Small red light flashes when going up and down
Post #531149 16th Oct 2019 5:44pm
Try battery disconnection procedure (to clear ECU and unconfuse EAS ECU)
or calibration of EAS required .
Post #531155 16th Oct 2019 6:52pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
I think Joe90 is right , I assume the old comp was goosed ? so its probably got old codes stored up from trying to achieve demands which the old comp couldn't meet ?
Post #531181 16th Oct 2019 8:56pm
S700TNG
This is the only think that’s coming up still won’t drop the front
Post #531221 17th Oct 2019 12:31pm
Did you try the battery disconnection procedure ? .
Post #531224 17th Oct 2019 1:22pm
S700TNG
Yes
Post #531230 17th Oct 2019 1:50pm
Suggest check all your air bags and sensors, then do a calibration .
Post #531266 17th Oct 2019 5:20pm
S700TNG
Starting to think height sensors are stiff
Post #531276 17th Oct 2019 6:46pm
S700TNG
Is there an Exhaust for the front suspension was it just one central exhaust delete all down
Post #531277 17th Oct 2019 6:47pm
There is a distribution valve at the front (front RHS wheelarch), at the back (rear RHS wheelarch) and on the reservoir .
Post #531284 17th Oct 2019 9:06pm
