Home > My Range Rover > Have I brought a lemon? |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 688 |
Keep going!
14th Oct 2019 2:24am |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 |
Doesn't sound like you've bought a lemon tbh but they can be very expensive cars to run particularly because the average run of the mill garage generally refuse to work on them.
14th Oct 2019 4:05pm |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 |
No Lemon, Just a few niggles & items that are applicable to these vehicles. As mentioned before try using an independent rather than JLR at Eastleigh.
14th Oct 2019 4:16pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4303 |
Hang in there. I bought mine as first one I saw with every knowledge I would have to spend on it. I did have a list of what to look for but didnt spot the oil cooler gasket leak. A year on and I'm still going through a job list..... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
14th Oct 2019 4:28pm |
dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529 |
Thanks for the reply’s guys.
14th Oct 2019 4:59pm |
Found the coolant leak? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
14th Oct 2019 5:32pm |
No mate. I can’t see anything in the engine bay.
14th Oct 2019 5:49pm |
Good idea. Ask them to diagnose. Might be something that can be fixed diy and save you dosh. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
14th Oct 2019 6:17pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
Do you have rear AC? If you do then you will also have rear heating, this means Ali coolant pipes with steel fixings running to the rear! A usual place to find coolant leaks |
14th Oct 2019 11:10pm |
Thanks Craig
15th Oct 2019 6:18am |
15th Oct 2019 7:29am |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3747 |
Keep going - it’s an 8 year old car and maintenance repairs are to be expected. If you think that’s expensive a major service and brakes pads & discs can set you back over £2200 at a main agents on later models with a big engine and Brembos 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
15th Oct 2019 8:12am |
Defo avoid main dealers once you've got tailgate sorted. Plenty around these parts! I found another in Haslemere. SLR Automotive. Superb customer service and ex LR guys Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
15th Oct 2019 8:26am |
There just doesnt seem be anything local to me in hythe, neraest is west 4x4 and thats 45mins away lol.. Regards
15th Oct 2019 8:51am |
