Home > Maintenance & Mods (L405) > Disable air suspension for jacking?
brad s1
2004 Range Rover HSE 4.4 V8 Giverny Green
l322 I used to just pull the battery, l405 the battery is a project to access. Jacking the car up to fit winter wheels I left some doors open, it still adjusts the suspension as you're jacking it up. Not a huge deal but in my earlier years I had one adjust itself off a jack stand so I always try to disable the system.
thanks,
Post #530879 14th Oct 2019 6:54pm
Winters already Shocked
Mine won’t be going on for another month
Post #530881 14th Oct 2019 7:04pm
brad s1
I was just test fitting, they do not fit. Sad
Post #530886 14th Oct 2019 7:46pm
Big Cry What do you have ?
AFAIK any 20” or higher L322 wheel will fit
I have 2 sets of L405 22’s Cool
Post #530889 14th Oct 2019 7:54pm
GraemeS
Australia
Remove the L405/L494 rear fuse panel fuse 23 to disable the suspension module. I remove the equivalent fuse in my MY12 L322.
Post #530894 14th Oct 2019 8:07pm
brad s1
They don't fit, I tried. I have another thread going (wheel spacers) the l322 20's barrel clears the AB brakes, but the spokes of that wheel do not clear. I bought a set of 502 style l405 wheels and am told those should clear. They'll be in some time next week and I'll test fit
Post #530920 15th Oct 2019 12:28am
