![]() | Home > Maintenance & Mods (L322) > Locking nut broken |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Not if its an L322 you have? The lockers are made to spin in the middle if you attempt to remove them without the correct key! ie that tool!
Benner91 Member Since: 18 Oct 2015 Location: Belfast Posts: 87 ![]() ![]() ![]() |
The key is fine it’s the bolt on the wheel that’s broken |
Oh! The only way now is to have them drilled out by a specialist!!! |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
You could try going at it with a hammer and cold chisel to see if you can get it to turn....
Bradders Member Since: 03 Dec 2018 Location: Gods own country Posts: 417 ![]() ![]() ![]() |
This outfit removed one for me without any difficulty. Cost me £20 as I called in to their premises.
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
only way I was able to take my off was with grinder and cut off wheel + dremel tool with cut off wheel and than hummer this in the nut,
2000 Disco. TD5 1975 series III |
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 413 ![]() ![]() ![]() |
And this is why I removed and replaced my locking wheel nuts with standard wheel bolts.
This is why locking wheel nuts should be fitted with greased threads and never over-tightened. If there is the slightest doubt about there condition they should either be replaced by new or replaced by plain nuts. Assuming you can get them off at all.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
Ditched mine an hour after purchase and got 5 normal ones on each corner |
Henda Member Since: 02 Aug 2018 Location: Gateshead Posts: 282 ![]() ![]() ![]() |
Ditto for locking nuts off
