Home > Maintenance & Mods (L322) > Radio interference
Henda
United Kingdom 2006 Range Rover Vogue TDV8 Zambezi Silver
Radio interference
Just nipped out to the shop and put on the rear demister a got a lot of radio interference any reasons as to why anyone Thumbs Up
Post #530442 9th Oct 2019 7:19pm
dazza1983
Had this in my e46 M3..
1st question did it go away when rear demister was switched off?
if yes then somewhere probably on a antenna there will be some small amount of corrosion when this happens the signal from the rear demister causes interference with the Ariel / antenna module Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #530445 9th Oct 2019 7:30pm
Henda
Yes it does
So will that be the roof mounted or the window ones because the inside was misted , I'll have a nose around cheers Thumbs Up
Post #530448 9th Oct 2019 7:55pm
dazza1983
Probably the window ones bud
The bmw ones were rear pillars which were super close to the rear windows.
You can try cleaning up the connections and could also try if possible re positioning the module or wires. Either of which should help. Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #530449 9th Oct 2019 8:21pm
