Home > Maintenance & Mods (L322) > Need some help identifying these suspension arms
l3222019
Brunei
Hello everyone
I hope you are are well
I had uneven tyre wear and took my RR (2006 L322 Autobiography) to a tyre/alignment shop for them to check it out. They inspected it and showed me these things that need replacing. The thicker arm had gone on the left hand side of the car and the thinner thing with the rubber cover had gone on the right hand side of the car. But they advised it's better to replace both sides. I've been told by a separate garage that replacing all those bits (inner/outer track rod and the arms) on both sides is about half a day's work, at around £200-£250. Is that reasonable?
Can someone help me with part numbers and where I could get them in the UK for a reasonable price?
Also, how can I tell if I have the newer air compressor or the older one?
Thanks everyone!
Post #530419 9th Oct 2019 5:22pm
welcome to the forum...theres a workshop manual in our wiki that might be of use to you.. ... - .- -.
Post #530420 9th Oct 2019 5:23pm
l3222019
Brunei
Thanks for the link!
I've looked through the workshop manuals and I'm now 100% sure that the bit with the rubber cover is the track rod. I also read another post which recommends changing both the inner and outer track rod at the same time as they can tend to get "seized" together. Also makes sense from a labour perspective I guess.
I think I've identified the component in the other picture as the front suspension's rear lower arm. Is that correct? And does it make sense for an arm like this to "go" or is it the case that the bushing or something needs replacing and the arm itself is fine?
Post #530435 9th Oct 2019 7:37pm
Gsxr1250dave
Just buy a complete kit off the bay less than 120 quid for booths sides upper/lower and ball joints
Post #530438 9th Oct 2019 7:47pm
l3222019
Brunei
Sounds sensible
Is it safe to get the tie/track rods off ebay too? I saw this post here saying it was a bad idea to get anything other than LR, I don't know if the poster was talking about tie/track rods or components in general
Post #530439 9th Oct 2019 8:06pm
Gsxr1250dave
I dont see why not iv never had an issue
Post #530440 9th Oct 2019 8:13pm
Henda
United Kingdom 2006 Range Rover Vogue TDV8 Zambezi Silver
Just had my front track rods done and yes both inner and outer as they were seized
The rear lower arm bushes starting to go can cause wear on the outside of the tyres and is normally a sign along with a brake tap when applied hard and fast at low speeds Thumbs Up
Post #530441 9th Oct 2019 8:15pm
GDM
United Kingdom 2006 Range Rover Vogue Td6 Zambezi Silver
l3222019 wrote:
Sounds sensible
Make sure you get well known brands when buying off E-bay.
Post #530453 9th Oct 2019 10:41pm
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
Or buy from forum sponsors Advanced Factors who tend to stock decent quality parts and are very helpful.
https://www.advancedfactors.co.uk/steering--suspension-52-c.asp 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #530459 10th Oct 2019 8:00am
GGDR
A lot of counterfeit action on eBay obvs
Use caution for mission critical parts
Thumbs Up Cheers, Greg
Post #530460 10th Oct 2019 8:12am
rjff
+1 for sponsors Advanced Factors.
Good help on the phone for idetification, cost etc, and if you then order online and say you're a forum member 5% off. Their upper and lower arms kit seems competatively priced. New bolts are not included but the WM says replace the old, so don't forget them as they aren't included in the kit price. Cheers
Richard
Gap IIDBT
Post #530496 10th Oct 2019 3:35pm
