Home > Maintenance & Mods (L322) > Reversing camera, making the guides move with the steering
Hozza12163
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
Sorry, it's the weekend and I only get to "play" with the car at the weekend
Does anyone know if the reversing guides can be made to move with the steering in a 2010 vogue?
These are the guides I have:
I have the IID tool and access to every single CCF option, even untested ones Shocked (Thanks Patrick!)
If it's simply enabling an option in the CCF does anyone have any ideas where and how?
Thanks in advance Bow down
dang it just found the answer in this forum, how do I delete this post? FFRR
2010 TDV8 3.6 Vogue
Stornoway Grey
Post #530170 6th Oct 2019 12:00pm
Baltic Blue
Tell us all the answer please.
Thumbs Up G reg 2.5VM Vogue Portofino red 1991- 1999
Post #530171 6th Oct 2019 12:24pm
Hozza12163
my bad, the answer is YOU CAN'T Big Cry
...unless you have the surround camera setup which uses a different camera with a different set of connectors Crying or Very sad
answer is courtesy of Cam_Tech_Craig so we know it can be trusted
2nd question then, what is the part number of the surround camera and fitting(s) I need to make this work? FFRR
2010 TDV8 3.6 Vogue
Stornoway Grey
Post #530172 6th Oct 2019 12:30pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Do you have to change the door mirrors to have the surround camera?
Post #530179 6th Oct 2019 2:25pm
Hozza12163
I would say so if you want the full set as there are cameras in the mirrors on the surround camera system (but I'm guessing)
However, I'm wondering if I could simply replace my standard rear camera with the rear camera from the surround camera set and thus obtain the moving lines? anyone? FFRR
2010 TDV8 3.6 Vogue
Stornoway Grey
Post #530182 6th Oct 2019 3:11pm
